Fw: "make install" fails building ne2000 on pc586
Harry Courtice hcourtice at optushome.com.au
Fri Sep 21 11:09:52 UTC 2001
Hello again
I still can't get "make install" to work for target pc586, but pc386 and
pc486 built OK.
In my /opt/rtems directory, there is no pc586/lib, but there is a /lib  in
the pc386 and pc486 directories. Is this because "make install" hasn't
finished yet (still failing for pc586) or is this a problem which is
stopping the "make install" working for pc586?
/opt/rtems
       pc386
             build-tools
             lib
             make
             samples
       pc486
             build-tools
             lib
             make
             samples
       pc586
             make
Thanks,
----- Original Message -----
From: "Harry Courtice" <hcourtice at optushome.com.au>
To: <rtems-users at OARCorp.com>
Sent: Friday, September 21, 2001 11:43 AM
Subject: "make install" fails building ne2000 on pc586
> To: <rtems-users at OARcorp.com>
> Sent: Thursday, September 20, 2001 8:38 PM
> Subject: "make install" fails building samples/hello
> > Hello
> > I am using cygwin/win98. I am trying to build RTEMS for a target pc386.
> When
> > I do "make install" I get the following error, and the make halts.
> Thanks for those answers. I've now got past hello, and am at my next
> sticking point. Is this easier with Linux, or does everyone have these
> problems?
> Here is my next error. It first came up during "make install", but I've
> re-run make here from the source directory where the problem is.
> BASH.EXE-2.04$
> BASH.EXE-2.04$ pwd
/data/rtems/tools/build-rtems/i386-rtems/c/pc586/lib/libbsp/i386/pc386/ne200
> 0
> BASH.EXE-2.04$ make install
/OPT/RTEMS/BIN/i386-rtems-gcc --pipe -B../../../../../../../../pc586/lib/ -s
> pecs
bsp_specs -qrtems -g -Wall -ansi -fasm    -mcpu=i586     -c -D__INSIDE_RTEMS
> _BS
> D_TCPIP_STACK__ -O4 -o o-optimize/ne2000.o
> ../../../../../../../../../rtems-4.5.
> 0/c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c
../../../../../../../../../rtems-4.5.0/c/src/lib/libbsp/i386/pc386/ne2000/ne
> 2000
> .c: In function `ne_init_hardware':
> 2000
> .c:447: warning: assignment from incompatible pointer type
> 2000
> .c: In function `ne_ioctl':
> 2000
> .c:897: `SIOCGIFADDR' undeclared (first use in this function)
> 2000
> .c:897: (Each undeclared identifier is reported only once
> 2000
> .c:897: for each function it appears in.)
> 2000
> .c:898: `SIOCSIFADDR' undeclared (first use in this function)
> 2000
> .c:902: `SIOCSIFFLAGS' undeclared (first use in this function)
> 2000
> .c:922: warning: implicit declaration of function `_IO'
> 2000
> .c:922: case label does not reduce to an integer constant
> 2000
> .c:899: warning: unreachable code at beginning of switch statement
> make: *** [o-optimize/ne2000.o] Error 1
> BASH.EXE-2.04$
> The problem seems to be that   .../c/src/libnetworking/sys/sockio.h is not
> being included, despite the fact that it is clearly included at the
> beginning of ne2000.c
> <snip>
> #include <bsp.h>
> #include <wd80x3.h>
> #include <stdio.h>
> #include <assert.h>
> #include <rtems/error.h>
> #include <rtems/rtems_bsdnet.h>
> #include <sys/param.h>
> #include <sys/mbuf.h>
> #include <sys/socket.h>
> #include <sys/sockio.h>            <----- Here it is..
> #include <net/if.h>
> #include <netinet/in.h>
> #include <netinet/if_ether.h>
> <snip>
> I put a "#error GOT HERE" in the beginning of the
> .../c/src/libnetworking/sys/sockio.h file, but it never came up during the
> make, so I don't think it's being included.
> Any more clues?
> Thanks,
> Harry Courtice
