Memory region tracking similar to malloc_stats?
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Sep 11 16:07:43 UTC 2001
Phil Torre wrote:
> Is there a simple way to access the current amount of space remaining
> in a region? Something like malloc_stats would be great, but I don't
> actually need the allocation history so much as the current free
> space (so as to watch for get_segment/return_segment leaks).
> It looks like the right thing to do is to walk the heap blocks like
> _Heap_Allocate() does, but I'll save myself some fumbling around if
> this work has already been done. Thanks...
How about this routine? :)
* Find amount of free heap remaining
size_t malloc_free_space( void )
It is based on the rtems_region_get_information()
call. It can return the following info:
* Information block returned by _Heap_Get_information
typedef struct {
unsigned32 free_blocks;
unsigned32 free_size;
unsigned32 used_blocks;
unsigned32 used_size;
} Heap_Information_block;
> Phil Torre phone: 425-820-6363 x234
> Design Engineer email: ptorre at zetron.com
> Switching Systems Group fax: 425-820-7031
> Zetron, Inc. web: http://www.zetron.com
joel at OARcorp.com On-Line Applications Research
