Help me in building gcc for target i386 for rtems
Joel Sherrill joel at OARcorp.com
Wed Sep 12 21:37:18 UTC 2001
This is just a guess since it appears that you have followed the
instructions correctly
and have gotten further than the symbolic link to gcc problem.
Look at the output of the "mount' command.  Is your source/build directory
in binary mode.  This is the output I get:
C:\cygwin\bin on /usr/bin type system (binmode)
C:\cygwin\lib on /usr/lib type system (binmode)
C:\cygwin on / type system (binmode)
CR/LF causes weird problems
--joel
latish sudheer wrote:
> hi,
>     I am very much new to rtems.I am trying to install it.I am having cygwin1.3.1 on windows Nt. While building gcc i am encountering some problems.
> Please help me in solving.
> my work as follows:
> 1.mkdir /source/rtems".
> 2.cd /source/rtems
> 3. bunzip2 /rtemsarchive/binutils-2.11.tar.bz2
> 4.tar xvf /rtemsarchive/binutils-2.11.tar
> 5.cd binutils-2.11
> 6.  patch -p1 < /rtemsarchive/binutils-2.11-rtems-20010409.diff
> 7. find . -name "*.rej" -print
>          no "ref" files found.
> 8.mkdir /build/rtems
> 9.cd /build/rtems
> 10.mkdir binutils
> 11.cd binutils
> 12./source/rtems/binutils-2.11/configure --target=i386-rtems \
>   --prefix=/opt/rtems
> 13.make all.
> 14.make info
> 15.make install
> 		----->No problems encountered
> 16.cd /source/rtems
> 17.tar xzvf /rtemsarchive/gcc-2.95.2.tar.gz
> 18.cd gcc-2.95.2
> 19.patch -p1 < /rtemsarchive/gcc-2.95.2-rtems-20010221.diff
> 20. find . -name "*.rej" -print
>         ---->     no "ref" files found.
> 21.cd /source/rtems
> 22.tar xzvf /rtemsarchive/newlib-1.9.0.tar.gz
> 23.cd newlib-1.9.0
> 24.patch -p1 < /rtemsarchive/newlib-1.9.0-rtems-20010221.diff
> 25.find . -name "*.rej" -print
> 26.PATH=/opt/rtems/bin:$PATH
>    PATH=/opt/rtems/i386-rtems/bin:$PATH
> 27.cd /source/rtems/gcc-2.95.2
> 28.ln -s /source/rtems/newlib-1.9.0/newlib newlib
> 29.I have remove some 3 files as mentioned in the rtems documentation.
>      	/source/rtems/gcc-2.95.2/libf2c
> 	/source/rtems/gcc-2.95.2/gcc/objc
> 	/source/rtems/gcc-2.95.2/gcc/f
> 30.cd /build/rtems
> 31.mkdir gcc
> 32.cd gcc
> 33./source/rtems/gcc-2.95.2/configure --target=i386-rtems \
>    --with-gnu-as --with-gnu-ld --with-newlib --verbose \
>    --enable-threads --prefix=/opt/rtems
> 34.make all
> 	Getting the same erros.as earlier.
> 35.make -k cross
>         Getting the same kind of errors
> 36.make -k install.
>         Its not getting installed.
> consturctionof GDB
> 37.cd /source/rtems
> 38. tar xzvf /rtemsarchive/gdb-5.0.tar.gz
> 39.cd gdb-5.0
> 40. patch -p1 < /rtemsarchive/gdb-5.0-rtems-20010314.diff
> 41.find . -name "*.rej" -print
> 42.cd /build/rtems/gdb
> 43. /source/rtems/gdb-5.0/configure --target=i386-rtems \
>   --prefix=/opt/rtems
> 44.make all
> 45.make info
> 46.make install
> with warm regards
> sudheer
> Get 250 color business cards for FREE!
> http://businesscards.lycos.com/vp/fastpath/
