Help me in building gcc for target i386 for rtems
latish sudheer
latish_sudheer at lycos.com
Wed Sep 12 20:54:00 UTC 2001
hi,
I am very much new to rtems.I am trying to install it.I am having cygwin1.3.1 on windows Nt. While building gcc i am encountering some problems.
Please help me in solving.
my work as follows:
1.mkdir /source/rtems".
2.cd /source/rtems
3. bunzip2 /rtemsarchive/binutils-2.11.tar.bz2
4.tar xvf /rtemsarchive/binutils-2.11.tar
5.cd binutils-2.11
6. patch -p1 < /rtemsarchive/binutils-2.11-rtems-20010409.diff
7. find . -name "*.rej" -print
no "ref" files found.
8.mkdir /build/rtems
9.cd /build/rtems
10.mkdir binutils
11.cd binutils
12./source/rtems/binutils-2.11/configure --target=i386-rtems \
--prefix=/opt/rtems
13.make all.
14.make info
15.make install
----->No problems encountered
16.cd /source/rtems
17.tar xzvf /rtemsarchive/gcc-2.95.2.tar.gz
18.cd gcc-2.95.2
19.patch -p1 < /rtemsarchive/gcc-2.95.2-rtems-20010221.diff
20. find . -name "*.rej" -print
----> no "ref" files found.
21.cd /source/rtems
22.tar xzvf /rtemsarchive/newlib-1.9.0.tar.gz
23.cd newlib-1.9.0
24.patch -p1 < /rtemsarchive/newlib-1.9.0-rtems-20010221.diff
25.find . -name "*.rej" -print
26.PATH=/opt/rtems/bin:$PATH
PATH=/opt/rtems/i386-rtems/bin:$PATH
27.cd /source/rtems/gcc-2.95.2
28.ln -s /source/rtems/newlib-1.9.0/newlib newlib
29.I have remove some 3 files as mentioned in the rtems documentation.
/source/rtems/gcc-2.95.2/libf2c
/source/rtems/gcc-2.95.2/gcc/objc
/source/rtems/gcc-2.95.2/gcc/f
30.cd /build/rtems
31.mkdir gcc
32.cd gcc
33./source/rtems/gcc-2.95.2/configure --target=i386-rtems \
--with-gnu-as --with-gnu-ld --with-newlib --verbose \
--enable-threads --prefix=/opt/rtems
34.make all
Getting the same erros.as earlier.
35.make -k cross
Getting the same kind of errors
36.make -k install.
Its not getting installed.
consturctionof GDB
37.cd /source/rtems
38. tar xzvf /rtemsarchive/gdb-5.0.tar.gz
39.cd gdb-5.0
40. patch -p1 < /rtemsarchive/gdb-5.0-rtems-20010314.diff
41.find . -name "*.rej" -print
42.cd /build/rtems/gdb
43. /source/rtems/gdb-5.0/configure --target=i386-rtems \
--prefix=/opt/rtems
44.make all
45.make info
46.make install
with warm regards
sudheer
Get 250 color business cards for FREE!
http://businesscards.lycos.com/vp/fastpath/
