Getting started - what & where to download?
Fernando RUIZ CASAS (E-mail)
fernando.ruiz at ctv.es
Thu Sep 13 11:49:16 UTC 2001
> -----Mensaje original-----
> De: Ralf Corsepius [mailto:corsepiu at faw.uni-ulm.de]
> Enviado el: jueves, 13 de septiembre de 2001 7:56
> CC: rtems-users at oarcorp.com
> Asunto: Re: Getting started - what & where to download?
> On Die, 2001-09-11 at 18:12, Joel Sherrill wrote:
> > Angelo Fraietta wrote:
> > > I would seriously recommend using the pre built RPMs if
> Mandrake will let you
> > > install them
> > If there is a problem with Mandrake and the RPMs, please report it.
> The only potential problem with Mandrake I am aware about, is
> potentially not correctly handling/detecting RPM's %_topdir (The
> directory which is used as root-directory for rpm-handling;
> /usr/src/redhat under RedHat, /usr/src/packages under SuSE) in RTEMS's
> rpm build-scripts (scripts/, scripts-ada/)
Maybe /usr/src/RPM?
There
./BUILD
./RPMS
./SOURCES
can be founded.
> I would appreciate if a Mandrake user could point out what is used by
> Mandrake.
> Thanks
> Ralf
