Getting started - what & where to download?
Ralf Corsepius corsepiu at faw.uni-ulm.de
Thu Sep 13 13:17:21 UTC 2001
On Don, 2001-09-13 at 13:49, Fernando RUIZ CASAS (E-mail) wrote:
> > -----Mensaje original-----
> > De: Ralf Corsepius [mailto:corsepiu at faw.uni-ulm.de]
> > Enviado el: jueves, 13 de septiembre de 2001 7:56
> > CC: rtems-users at oarcorp.com
> > Asunto: Re: Getting started - what & where to download?
> > On Die, 2001-09-11 at 18:12, Joel Sherrill wrote:
> > > Angelo Fraietta wrote:
> > > > I would seriously recommend using the pre built RPMs if
> > Mandrake will let you
> > > > install them
> > > If there is a problem with Mandrake and the RPMs, please report it.
> > The only potential problem with Mandrake I am aware about, is
> > potentially not correctly handling/detecting RPM's %_topdir (The
> > directory which is used as root-directory for rpm-handling;
> > /usr/src/redhat under RedHat, /usr/src/packages under SuSE) in RTEMS's
> > rpm build-scripts (scripts/, scripts-ada/)
> Maybe /usr/src/RPM?
> There
>  ./BUILD
>  ./RPMS
>  ./SOURCES
> can be founded.
Yes, this sounds like being the piece of info I was looking for ;)
Ralf
