Recipe to newbie was Help me in building gcc for target i386 for rtems
Maarten.Kruger at ziton.spx.com
Fri Sep 14 12:45:43 UTC 2001
Good day,
What files (specifically) can't you find? Maybe I can help...
Maarten Kruger (newbie myself)
Ng
<HNguyen at KRAUT To: rtems-users at oarcorp.com
KRAMER.DE> cc:
Subject: RE: Recipe to newbie was Help me in
01/09/14 03:15 building gcc for target i386 for rtems
PM
Fernando.
Thank for your recipe but you know the files, cited in your mail, do not
exist on ftp.OARcorp.com so we, as newbie, can not follow 1 by 1 your
recipe.
The informations in Started.pdf are not up to date to the files on
ftp.OARcorp.com
Could you like take a look on the files on ftp.OARcorp.com and give us as
newbie an updated recipe
Thank so much
> -----Original Message-----
> From: Fernando RUIZ CASAS [SMTP:correo at fernando-ruiz.com]
> Sent: Wednesday, September 12, 2001 11:35 PM
> To: latish_sudheer at lycos.com; rtems-users at oarcorp.com
> Subject: Recipe to newbie was Help me in building gcc for
target
> i386 for rtems
> Hi.
> Well.
> Download the Getting Started with RTEMS from ftp.OARcorp.com
> 'started.pdf'
> There you can see the traditional system to install rtems
4.5.0Beta3
> in
> Linux.
> (The last version of cygwin(2.78.2.9) is very close to linux
> environment)
> Download the lastest version of cygwin (recomended) from
> sources.redhat.com.
> Setup the downloaded packages and start a new cygwin bash
session.
> Put attention choosing default file type DOS in the install
step.
> With this the cr/lf or cr end-of-line can be readed without
> problems.
> Move all the downloaded files in /home/Your_account/archives
> (recomended)
> chdir to /home/Your_account and
> untar the files and apply the patches.(the c_tools)
> * binutils-2.10.tar.gz (binutils-2.10-rtems-20000726.diff)
> * gcc-2.95.2.tar.gz (gcc-2.95.2-rtems-20001226.diff)
> * newlib-1.9.0.tar.gz (newlib-1.9.0-rtems-20001219.diff)
> You can of course download the last versions of these
files.(Your
> versions)
> And the last snapshot if you want to use it.
> * rtems-ss-20010816.tar.gz
> The new format bz2 can be untared with 'tar xvjf file.tar.bz2'
> directly.
> Download
> * c_build_scripts-4.5.0-beta3a.tgz.
> It contains the 'bit' and 'bit_rtems' script files to make all
of
> this
> for newbies like us.
> Now you only need setup the user.cfg touching the variables
inside.
> Modify the path adding (if you choose /opt/rtems like --prefix
> (default in
> user.cfg))
> PATH=/opt/rtems/bin:$PATH
> Make a little trick to get this compilation.
> ln gcc.exe cc.exe in /bin
> ln gmake.exe make.exe in /bin
> in order to compile without problems and another last trick.
> change with regedit.exe
> HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\WOW\cmdline
from
> '%SystemRoot%\system32\ntvdm.exe' to
> '%SystemRoot%\system32\ntvdm.exeXXX'
> to disable the execution of msdos 16 bits programs while your
> or
> c_tools compilation.
> Don't forget that after your successfull compilation undo the
> changes.
> The user applications don't need to compile this trick.
> Now, executing
> ./bit i386
> a new 'build-i386-tools' directory will be created and
> the tools will be configured there.
> after this
> ./bit i386 pc686
> a new 'build-i386-rtems' will be crated and
> the rtems libraries will be configured there.
> You can see after this all the /opt/rtems subdirectories with
your
> binaries
> and libraries to compile
> your new user programs.
> With this system I can compile my programs without problems.
> (perhaps any mistake can be done, sorry in advance)
> You can see that all of this is like unix environment.
> This system in more easy to install and
> all the linux instructions can be used.
> Enjoy it.
> Fernando RUIZ CASAS
> home: correo at fernando-ruiz.com
> work: fernando.ruiz at ctv.es
