RTEMS++
Chris Johns cjohns at cybertec.com.au
Tue Sep 18 01:54:16 UTC 2001
"Victor V. Vengerov" wrote:
> Hello, RTEMS Users,
> I just like to clarify, are the rtems++ library and appropriate test
> should work?
I understand they should.
> We have tried to run it with our BSP and encountered with problems. We
> are not
> a C++ guru, but in our understanding, test may not work correctly.
> May I assume that rtems++ test correct? Did somebody have problems
> with it?
What target are you using ?
 Chris Johns, cjohns @ cybertec.com.au
