RTEMS++
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Sep 18 10:58:11 UTC 2001
Chris Johns wrote:
> "Victor V. Vengerov" wrote:
> > Hello, RTEMS Users,
> > I just like to clarify, are the rtems++ library and appropriate test
> > should work?
> I understand they should.
> > We have tried to run it with our BSP and encountered with problems. We
> > are not
> > a C++ guru, but in our understanding, test may not work correctly.
> > May I assume that rtems++ test correct? Did somebody have problems
> > with it?
> What target are you using ?
It is very easy to doublecheck something on a simulator. There
are RPMS available for both sparc-rtems and powerpc-rtems and the
erc32 and psim BSPs can be built in minutes.
BSPs must properly setup to support C++. It can be tricky
to get the sections just so. :)
> Chris Johns, cjohns @ cybertec.com.au
--joel
