to make a prom image...
Gerke Kok
gerke.kok at tpa-nl.com
Thu Sep 27 12:40:16 UTC 2001
Hello,
this sounds like the problem I had with m68k-rtems-objcopy. It looks like the silly thing reallocates your code... Can anybody shead any light on this? It realy is unhandy... I posted somthing under the subject "ObjCopy" and did not get any response. Looks like I am the only one using ObjCopy...
Thanks for any comments and help that will be given!
Gerke
*********** REPLY SEPARATOR ***********
On 27/09/01 at 11:38 Stan wrote:
Hello,
I try to make a prom image;
can you help me ?
after make,
m68k-rtems-size : text=47984 data=2208 bss=14512 dec=64704 hex=fcc0
and,
m68k-rtems-objcopy: warning :
--change-section-vma .data = 0x00000000 never used
--change-section-lma .data = 0x00000000 never used
Can you tell me if linkcmd and hello.num are good ?
Thank's.
URL: <http://lists.rtems.org/pipermail/users/attachments/20010927/75a4c86e/attachment-0001.html>
