network boot
Vivek Vaid vaid at me.iitb.ac.in
Fri Sep 28 05:51:50 UTC 2001
On Thu, 27 Sep 2001, Joel Sherrill wrote:
> Vivek Vaid wrote:
> > However, using netboot might take you one step behind the standard of
> > using DCHP. since i found, netboot required a simple bootp server. (which
> > does not come with Redhat linux 6.2 or above, so you will have to get it
> > from older version, or rpmfind.net).
> > Hence on server side you only need to enable bootp-server & tftp.
> > (whos config file bootptab is much simple that DHCP.conf)
> I don't understand. Are you saying that you are one step behind because
> RedHat is leaving out bootp in late model releases?
Yes. (on most websites I read, its better use DHCPD ,since it has dhcp
plus bootp, rather than only bootpd)
> Or is there a problem on the RTEMS side?
No.
regards,
Vivek
