information about resources of actual application
Ralf Corsepius corsepiu at faw.uni-ulm.de
Fri Sep 28 14:22:16 UTC 2001
Am Fre, 2001-09-28 um 16.09 schrieb 1001686153:
> Aaron J. Grier wrote:
> >On Thu, Sep 27, 2001 at 03:08:25PM +0200, Jan.Suchotzki at de.abb.com wrote:
> >> I recognised, that the right version (which makes some output) of
> >> malloc_dump() will be called only if RTEMS_DEBUG is defined.  I have
> >> compiled and installed my Snapshot with VARIANT=DEBUG and compile my
> >> appilcation with make debug. I´ve included rtems/libcsupport.h for
> >> malloc_dump().
> >> Can somebody tell me why it didn´t work? I try to execute it with the
> >> m68k-efi332 bsp.
> >when compiling RTEMS you need to add XCPPFLAGS=-DRTEMS_DEBUG, like so:
> >make VARIANT=debug XCPPFLAGS=-DRTEMS_DEBUG
As you seem to be using the snapshots, I actually doubt this to be
correct.
With the snapshots, configuring with --enable-rtems-debug probably is
what you want.
Ralf
