Termios Problem
Joel Sherrill
joel at OARcorp.com
Fri Sep 28 17:53:20 UTC 2001
Thought I would move this back to the list. :)
Thomas Doerfler wrote:
> Hello Mike,
>> I traced the problem to the following functions. The
> transmit interrupt
>> handler
>> was calling the function rtems_termios_dequeue_characters().
> This function
>> increments a dequeue length variable and then calls the
> function
>> rtems_termios_refill_transmitter(). The problem is that
> when the transmit
>> buffer is empty, the dequeue length variable is not reset to
> zero. So the
>> next valid transmit request was sending extra data.
> Resetting the dequeue
>> length variable to zero, fixes the problem.
> If I got you right, then the termios tx buffer pointers and
> t_dqlen run somewhat out of sync. I think this might happen,
> when you call rtems_termios_dequeue_characters() with a "len"
> parameter, that is bigger than it should be. Keep in mind,
> that you always should set the "len" parameter to the number
> of bytes that have been actually sent out. So when you have
> sent three bytes, len should be 3 (and not the maximum number
> of characters that the hardware is able to send out in after
> one service). When you get "empty" transmit interrupts (maybe
> they signal, that the transmitter IS empty, and not HAS JUST
> BECOME empty), then you should not call
> rtems_termios_dequeue_characters() at all.
> Hm. Maybe that helps a bit. I am currently working with rtems-
> 4.5.0, so there is no coldfire bsp included. If you like, you
> can send me the coldfire "console" module and I might have a
> look at it (out of curiosity).
> Bye,
> Thomas.
>> Any thoughts? Should this problem be fixed with a simple
> change to
>> the termios code? Or should I have to make the fix in the
> BSP code
>> to ensure that transmit iterrupts are not enabled when the
> buffer is empty.
>> Thanks
>> Mike Siers
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler Herbststrasse 8
> D-82178 Puchheim Germany
> email: Thomas.Doerfler at imd-systems.de
> PGP public key available at: http://www.imd-
> systems.de/pgp_key.htm
joel at OARcorp.com On-Line Applications Research
