Fw: Re: Re: how can i build the rtems multiprocess demos?
zzc
zhichaozhang at yahoo.com
Sun Apr 7 01:13:12 UTC 2002
>> I can'nt build the multiprocessing demo,through i run configure and build scripts under linux
>> like this:
>> ../rtems/./configure --target=i386-rtems --enable-mutliprocessing --enable-test
#1. --enable-multiprocessing is spelled incorrectly. :)
>> make RTEMS_BSP="pc386" install
>> When it finished,the other demos is ok.except the the mptests demos.
>> How can i build the multiprocessing demos???
#2. RTEMS multiprocessing requires some BSP specific drivers to enable
communications between the processors. This has never been implemented
for SMP-PCs.
#2.Could you tell me which platform did the multiprocessing function implemented on?
>>But the tests should build but (I think) fail to link if you spelled
>>the option right.
#3.I build the tests with the correct parameters,the hello,ticker...demos are ok,
and the base_sp demo also is ok,but the base_mp demo's directory only
have Makefile script,and two empty directories named node1 and node2.
>> Any advice are welcome.
joel at OARcorp.com On-Line Applications Research
URL: <http://lists.rtems.org/pipermail/users/attachments/20020407/b2816e14/attachment.html>
