how to build a connection using gdb stub???
Naster
rtemswq at yahoo.com.cn
Tue Apr 9 08:27:18 UTC 2002
Hello all:
I want to crossing debug base_sp using gdb stub,
but i can not build a connection between host and
target successfully.
Host :
operation system: Redhat linux 7.2
cpu: Inter pentium4, 1.5GHZ
Target:
cpu: inter pentium 166MHZ
And i have connected these two computers with a serial
line(serial port com2 to com2).
On the target,i have downloaded and run base_sp.exe
with grub stage2,and then base_sp.exe stopped at
breakpoint, correctly.
On the host ,in base_sp directory, i run :
i386-rtems-gdb --nx o-optimize/base_sp.exe,and then i
received messages " Ignoring packet error ,continuing
couldn't establish connection to remote target
Malformed response to offset query,time out"
I modified base_sp soruce code as below:
##### init.c #####
#define CONFIGURE_INIT
#include "system.h"
#include <uart.h> /*modified*/
#define ARGUMENT 0
rtems_task Init(
rtems_task_argument argument
extern int
BSPConsolePort; /*modified*/
rtems_name task_name;
rtems_id tid;
rtems_status_code status;
if(BSPConsolePort!=BSP_UART_COM2)
{i386_stub_glue_init(BSP_UART_COM2);
else
{i386_stub_glue_init(BSP_UART_COM1);
set_debug_traps();/*modified*/
i386_stub_glue_init_breakin();/*modified*/
task_name = rtems_build_name( 'T', 'A', '1', ' ' );
status = rtems_task_create( task_name, 1,
RTEMS_MINIMUM_STACK_SIZE,
RTEMS_INTERRUPT_LEVEL(0),
RTEMS_DEFAULT_ATTRIBUTES, &tid );
status = rtems_task_start( tid, Application_task,
ARGUMENT );
status = rtems_task_delete( RTEMS_SELF );
####### apptask.c ######
#include "system.h"
rtems_task Application_task(
rtems_id tid;
status = rtems_task_ident( RTEMS_SELF,
RTEMS_SEARCH_ALL_NODES, &tid );
printf( "\nApplication task was invoked with
argument (%d) "
"and has id of 0x%x\n", argument, tid );
breakpoint(); /*modified*/
printf( "\n*** END OF SAMPLE SINGLE PROCESSOR
APPLICATION ***\n" );
exit( 0 );
Thanks for any help.
David
_________________________________________________________
Do You Yahoo!?
到世界杯主题公园玩一玩,赢取世界杯门票乐一乐。
http://cn.worldcup.yahoo.com/
