ARM inline assembly patch
Jay Monkman
jtm at smoothsmoothie.com
Wed Apr 17 23:52:42 UTC 2002
I'm trying to get RTEMS working on an ARM940T board, and ran
into a problem where a function was overwriting a passed in
parameter before using or saving it. It turns out some inline
assembly code (CPU_ISR_Disable and CPU_ISR_Enable) modifies a
register without telling the compiler.
Here's a patch against snapshot-20020301 that fixes it. I've also
consolidated the 3 asm statements into one.
--- rtems-ss-20020301/c/src/exec/score/cpu/arm/rtems/score/cpu.h Wed Nov 28 12:15:58 2001
+++ cvs-rtems/c/src/exec/score/cpu/arm/rtems/score/cpu.h Wed Apr 17 18:41:22 2002
@@ -540,9 +540,10 @@
#define _CPU_ISR_Disable( _level ) \
(_level) = 0; \
- asm volatile ("MRS r0, cpsr \n" ); \
- asm volatile ("ORR r0, r0, #0xc0 \n" ); \
- asm volatile ("MSR cpsr, r0 \n" ); \
+ asm volatile ("MRS r0, cpsr \n" \
+ "ORR r0, r0, #0xc0 \n" \
+ "MSR cpsr, r0 \n" \
+ : : : "r0"); \
@@ -553,9 +554,10 @@
#define _CPU_ISR_Enable( _level ) \
- asm volatile ("AND r0, r0, #0xFFFFFF3F \n" ); \
+ "AND r0, r0, #0xFFFFFF3F \n" \
+ : : : "r0" ); \
Jay Monkman The truth knocks on the door and you say "Go away, I'm
monkman at jump.net looking for the truth," and so it goes away. Puzzling.
- from _Zen_and_the_Art_of_Motorcycle_Maintenance_
