Netdemo examples.
Bill Butler billb at tnex.com
Mon Apr 22 15:05:20 UTC 2002
> From: Eric Norum [mailto:eric.norum at usask.ca]
> On Monday, April 22, 2002, at 08:06 AM, Bill Butler wrote:
> > I bet this has been answered before but I still can not get the
> > search to work and have searched back to last april with now luck..
> > I have the Netdemo4-5.0/netdemo up and working for the most part on
> > i386/PC486 BSP. I using the 4.5.0 release (no snapshots).  I can get
the
> > demo to come up and request and receive an IP using BOOTP when in
BootP
> > mode. It displays no errors and is able to create, bind, listen,
accept
> > sockets.
> > The "u" test seems to work but "t" or tcp/ip test times out --
Giving
> > "Can't connect socket: Connection timed out".
> > I have also tried to hardcode its IP with the same results.
> Is the TCP`discard' socket active on the machine you're trying to
> connect to from the RTEMS machine?
Unsure.. I need to look into this since I'm not really familiar with
Discard socket. I have tried both uncommenting the 127.0.0.0 and setting
it to the machine I'm trying to use telnet on. (ie 192.168.1.11- my
linux box)
> > Trying to ping the pc running Rtems/netdemo times out and trying to
> > connect using telnet 192.168.1.16 24742 does not work as advertised.
> > To me this sounds like a TCP/IP problem more than the demo problem
and I
> > am hesitant to move on with development until I get this demo
working.
> Is the RTEMS machine configured to accept broadcast packets?
> Can you run a packet sniffer and see exactly what's happening on your
> network?
I have not changed anything on the demo except to enable BootP and add
more files handles. When I use the sniffer It does not look to me that
the Rtems box tries to except the telnet session. But I need to look
into this more but I really thought the netDemo should work pretty much
as is.
Thanks
Bill
