newbie question about gen68360
Gerke Kok TPA
gerke.kok at tpa-nl.com
Fri Apr 26 14:51:52 UTC 2002
Hi Claudio Imberlina,
you can create srec files with the tool:
m68k-rtems-objcopy -o srec your_file.exe
This will create a file your_file.srec. You can read about all of this with:
man objcopy
This will cover the i386 version of objcopy but it will also work for
the m68k version. This tool will also enable you to split the
your_file.exe over two proms if needed. (or four...)
Hope this helps,
Gerke Kok
Claudio Imberlina wrote:
> Hello,
> I have a board based on a 68en360, very similar to an ACE360, I
> installed the toolchain and rtems, then I make the example "hello",
> and obtained a file o-optimize/hello.exe.
> My question is, from this point, wich are the next step to follow, to
> burn a flash (29f040) with the firmware, to have the system running.
> How I can obtain an srec file from hello.exe, etc.
> Thanks in advance
> Claudio Imberlina
URL: <http://lists.rtems.org/pipermail/users/attachments/20020426/10f3a9f5/attachment.html>
