MPC8260ADS and Linux
Fri Apr 26 17:05:03 UTC 2002
Steven Grunza wrote:
> Currently not working as expected is "./bit_rtems powerpc"
> The end of the output is:
> configuring in powerpc-rtems/c
> running /bin/sh ../../../rtems-4.5.0/c/configure  --target=powerpc-rtems
> --prefix=/home/rtems --disable-hwapi --disable-multiprocessing --enable-cxx
> --enable-rdbg --disable-tests --enable-networking --enable-posix
> --enable-itron --cache-file=./config.cache --srcdir=../../../rtems-4.5.0/c
> creating cache ./config.cache
> checking for RTEMS Version... 4.5.0
> checking host system type... i386-unknown-netbsd1.5.2
> checking target system type... powerpc-unknown-rtems
> checking build system type... i386-unknown-netbsd1.5.2
> checking rtems target cpu... powerpc
> checking for a BSD compatible install... /usr/bin/install -c
> checking whether build environment is sane... yes
> checking whether make sets ${MAKE}... yes
> checking for working aclocal... found
> checking for working autoconf... found
> checking for working automake... found
> checking for working autoheader... found
> checking for working makeinfo... found
> checking whether to enable maintainer-specific portions of Makefiles... no
> checking if cpu powerpc is supported... yes
> checking for bsps...  .cvsignore dmv177 eth_comm helas403 mvme2307 mcp750
> papyrus ppcn_60x psim score603e .. done
> checking for make/custom/.cvsignore.cfg... configure: error: no
> configure: error: ../../../rtems-4.5.0/c/configure failed for c
> Could not successfully configure into build-powerpc-rtems!
Weird that it is picking up .cvsignore as a possible BSP name.
But you don't want to build all PowerPC BSPs.  Add an option
like this to your configure command
  --enable-rtemsbsp=mpc860ads
or whatever the proper name of the BSP is.
> My directories look like the following after attempting to build
> rtems-4.5.0
> drwxr-xr-x  14 grunza  hardware  1024 Jan 13  2000 binutils-2.9.5.0.24
> -rwxr-xr-x   1 grunza  hardware  6064 Jul 10  2000 bit
> -rwxr-xr-x   1 grunza  hardware  4828 Jan  4  2000 bit_gdb
> -rwxr-xr-x   1 grunza  hardware  8477 Jun 12  2000 bit_rtems
> drwxr-xr-x   6 root    hardware   512 Apr 26 11:47 build-powerpc-rtems
> -rwxr-xr-x   1 grunza  hardware  6558 Feb 11  2000 common.sh
> drwxr-xr-x  16 grunza  hardware  1024 Apr 26 10:28 gcc-2.95.2
> drwxr-xr-x  15 grunza  hardware  1024 Apr 26 10:58 gdb-4.18
> drwxr-xr-x   7 grunza  hardware  1024 Nov 20  1999 newlib-1.8.2
> drwxr-xr-x  10 grunza  hardware  1024 Jul 24  2000 rtems-4.5.0
> -rw-r--r--   1 grunza  hardware  3066 Apr 26 11:38 user.cfg
> My user.cfg is attached to this message.
> My system is:
> toor at pc-grunza-p 94% uname -a
> NetBSD pc-grunza-p 1.5.2 NetBSD 1.5.2 (JAGUAR) #2: Tue Apr  9 11:05:01 EDT
> 2002     root at pc-grunza-p:/usr/src/sys/arch/i386/compile/JAGUAR i386
> grunza at pc-grunza-p 178% make --version
> GNU Make version 3.79.1, by Richard Stallman and Roland McGrath.
> Built for i386--netbsd
> Copyright (C) 1988, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 2000
>         Free Software Foundation, Inc.
> This is free software; see the source for copying conditions.
> There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
> PARTICULAR PURPOSE.
> Report bugs to <bug-make at gnu.org>.
> grunza at pc-grunza-p 179% sed --version
> GNU sed version 3.02
> Copyright (C) 1998 Free Software Foundation, Inc.
> This is free software; see the source for copying conditions.  There is NO
> warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE,
> to the extent permitted by law.
> grunza at pc-grunza-p 180% powerpc-rtems-gcc --version
> 2.95.2
> NOTE:  I'm running as root for the ./bit scripts so the installation can
> occur
> Sorry for the long post...
> Ralf Corsepius wrote:
> > Am Fre, 2002-04-26 um 16.21 schrieb Mike Siers:
> > > Hi Joel,
> > > Sorry for the confusion.  Here is the quick and dirty recipe:
> > > 1) Install OpenBSD
> > > 2) Install the following packages or ports:
> > >      - gettext
> > >      - gmake
> > >      - autoconf
> > >      - automake
> > >      - libtool
> > >      - m4
> > gettext and libtool are not required by RTEMS nor by any of the tools
> > involved into RTEMS.
> > > 3) Get and build GNU sed source (installs to /usr/local/bin)
> > gm4 and gsed may be necessary on some platforms, because the native ones
> > shipped on some systems are too limited or broken for use with autoconf.
> > > 4) Get and build GNU patch source (installs to /usr/local/bin)
> > I have no idea why you need this, may-be the native patch is not able to
> > handle unified context diffs.
> > > 5) Make symbolic link from /usr/local/bin/gmake to /usr/local/bin/make
> > > 6) Make symbolic link from /usr/local/bin/gm4   to /usr/local/bin/m4
> > > 7) Modify path to have /usr/local/bin before other directories
> > In addition to this, you will need a sufficiently good shell for RTEMS
> > and for the autotools, because some shells on some systems are known to
> > be severly broken and the auto*tools not having yet been adapted to
> > these shells' deficiencies
> > (Known to be problematic at present time: Newer systems using zsh-3.0.x
> > and ash as default shells)
> > Ralf
> "Luke, you're going to find that many | Steven Grunza
> of the truths we cling to depend      | voice:  (856) 787 - 2759
> greatly on our own point of view."    | fax:    (856) 866 - 2033
>  - Obi Wan Kenobi, Return of the Jedi | e-mail: steven_grunza at ieee.org
>    user.cfg    Type: Proxy Auto-Config (application/x-ns-proxy-autoconfig)
>            Encoding: 7bit
