MPC8260ADS and Linux
Andy Dachs iwe at fsmail.net
Fri Apr 26 19:51:01 UTC 2002
Hi Steven,
This could be an easy one.. the bit scripts are deprecated and replaced by "./configure" and "make all install" but if you want to use them the syntax is like this:
./bit powerpc
builds you the tools (binutils, gcc and newlib) for any powerpc target.  Check user.cfg before running to make sure you're pointing at the right directories for the sources.
So far you have nothing that is specific to mpc8260 (or any BSP) so the next step is to build RTEMS and one or more BSPs:
for instance:
./bit_rtems powerpc psim
would get you RTEMS and the simulator.
If you want the 8260 ADS bsp you'll need a recent snapshot. From your post it looks as though you're building 4.5.0 which definitely doesn't have the 8260 BSP.  You may also need more recent tools than you've got currently (binutils-2.11, gcc-2.95.3 and newlib-1.9.0 are what I'm using).
When you've got a recent snaphot (and user.cfg points to it) run:
./bit_rtems powerpc mpc8206ads
Good luck!
Andy
> -----Original Message-----
> From: Joel Sherrill [mailto:joel.sherrill at OARcorp.com]
> Sent: Friday, April 26, 2002 6:05 PM
> To: Steven Grunza
> Cc: Ralf Corsepius; RTEMS Users
> Subject: Re: MPC8260ADS and Linux
> Steven Grunza wrote:
> > Currently not working as expected is "./bit_rtems powerpc"
> > The end of the output is:
> > configuring in powerpc-rtems/c
> > running /bin/sh ../../../rtems-4.5.0/c/configure  --target=powerpc-rtems
> > --prefix=/home/rtems --disable-hwapi --disable-multiprocessing
> --enable-cxx
> > --enable-rdbg --disable-tests --enable-networking --enable-posix
> > --enable-itron --cache-file=./config.cache --srcdir=../../../rtems-4.5.0/c
> > creating cache ./config.cache
> > checking for RTEMS Version... 4.5.0
> > checking host system type... i386-unknown-netbsd1.5.2
> > checking target system type... powerpc-unknown-rtems
> > checking build system type... i386-unknown-netbsd1.5.2
> > checking rtems target cpu... powerpc
> > checking for a BSD compatible install... /usr/bin/install -c
> > checking whether build environment is sane... yes
> > checking whether make sets ${MAKE}... yes
> > checking for working aclocal... found
> > checking for working autoconf... found
> > checking for working automake... found
> > checking for working autoheader... found
> > checking for working makeinfo... found
> > checking whether to enable maintainer-specific portions of Makefiles... no
> > checking if cpu powerpc is supported... yes
> > checking for bsps...  .cvsignore dmv177 eth_comm helas403 mvme2307 mcp750
> > papyrus ppcn_60x psim score603e .. done
> > checking for make/custom/.cvsignore.cfg... configure: error: no
> > configure: error: ../../../rtems-4.5.0/c/configure failed for c
> > Could not successfully configure into build-powerpc-rtems!
> Weird that it is picking up .cvsignore as a possible BSP name.
> But you don't want to build all PowerPC BSPs.  Add an option
> like this to your configure command
>   --enable-rtemsbsp=mpc860ads
> or whatever the proper name of the BSP is.
> > My directories look like the following after attempting to build
> > rtems-4.5.0
> > drwxr-xr-x  14 grunza  hardware  1024 Jan 13  2000 binutils-2.9.5.0.24
> > -rwxr-xr-x   1 grunza  hardware  6064 Jul 10  2000 bit
> > -rwxr-xr-x   1 grunza  hardware  4828 Jan  4  2000 bit_gdb
> > -rwxr-xr-x   1 grunza  hardware  8477 Jun 12  2000 bit_rtems
> > drwxr-xr-x   6 root    hardware   512 Apr 26 11:47 build-powerpc-rtems
> > -rwxr-xr-x   1 grunza  hardware  6558 Feb 11  2000 common.sh
> > drwxr-xr-x  16 grunza  hardware  1024 Apr 26 10:28 gcc-2.95.2
> > drwxr-xr-x  15 grunza  hardware  1024 Apr 26 10:58 gdb-4.18
> > drwxr-xr-x   7 grunza  hardware  1024 Nov 20  1999 newlib-1.8.2
> > drwxr-xr-x  10 grunza  hardware  1024 Jul 24  2000 rtems-4.5.0
> > -rw-r--r--   1 grunza  hardware  3066 Apr 26 11:38 user.cfg
> > My user.cfg is attached to this message.
> > My system is:
> > toor at pc-grunza-p 94% uname -a
> > NetBSD pc-grunza-p 1.5.2 NetBSD 1.5.2 (JAGUAR) #2: Tue Apr  9 11:05:01 EDT
> > 2002     root at pc-grunza-p:/usr/src/sys/arch/i386/compile/JAGUAR i386
> > grunza at pc-grunza-p 178% make --version
> > GNU Make version 3.79.1, by Richard Stallman and Roland McGrath.
> > Built for i386--netbsd
> > Copyright (C) 1988, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 2000
> >         Free Software Foundation, Inc.
> > This is free software; see the source for copying conditions.
> > There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
> > PARTICULAR PURPOSE.
> > Report bugs to <bug-make at gnu.org>.
> > grunza at pc-grunza-p 179% sed --version
> > GNU sed version 3.02
> > Copyright (C) 1998 Free Software Foundation, Inc.
> > This is free software; see the source for copying conditions.  There is NO
> > warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
> PURPOSE,
> > to the extent permitted by law.
> > grunza at pc-grunza-p 180% powerpc-rtems-gcc --version
> > 2.95.2
> > NOTE:  I'm running as root for the ./bit scripts so the installation can
> > occur
> > Sorry for the long post...
> > Ralf Corsepius wrote:
> > > Am Fre, 2002-04-26 um 16.21 schrieb Mike Siers:
> > > > Hi Joel,
> > > > Sorry for the confusion.  Here is the quick and dirty recipe:
> > > > 1) Install OpenBSD
> > > > 2) Install the following packages or ports:
> > > >      - gettext
> > > >      - gmake
> > > >      - autoconf
> > > >      - automake
> > > >      - libtool
> > > >      - m4
> > > gettext and libtool are not required by RTEMS nor by any of the tools
> > > involved into RTEMS.
> > > > 3) Get and build GNU sed source (installs to /usr/local/bin)
> > > gm4 and gsed may be necessary on some platforms, because the native ones
> > > shipped on some systems are too limited or broken for use with autoconf.
> > > > 4) Get and build GNU patch source (installs to /usr/local/bin)
> > > I have no idea why you need this, may-be the native patch is not able to
> > > handle unified context diffs.
> > > > 5) Make symbolic link from /usr/local/bin/gmake to /usr/local/bin/make
> > > > 6) Make symbolic link from /usr/local/bin/gm4   to /usr/local/bin/m4
> > > > 7) Modify path to have /usr/local/bin before other directories
> > > In addition to this, you will need a sufficiently good shell for RTEMS
> > > and for the autotools, because some shells on some systems are known to
> > > be severly broken and the auto*tools not having yet been adapted to
> > > these shells' deficiencies
> > > (Known to be problematic at present time: Newer systems using zsh-3.0.x
> > > and ash as default shells)
> > > Ralf
> > "Luke, you're going to find that many | Steven Grunza
> > of the truths we cling to depend      | voice:  (856) 787 - 2759
> > greatly on our own point of view."    | fax:    (856) 866 - 2033
> >  - Obi Wan Kenobi, Return of the Jedi | e-mail: steven_grunza at ieee.org
> >    user.cfg    Type: Proxy Auto-Config (application/x-ns-proxy-autoconfig)
> >            Encoding: 7bit
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel at OARcorp.com                 On-Line Applications Research
>    Support Available             (256) 722-9985
