Exception 6
Angelo Fraietta
angelo_f at bigpond.com
Sun Apr 14 22:52:45 UTC 2002
The problem is still there, however, the results vary depending upon
what I do within the code. I believe that it has something to do with
the way the code is packed and aligned. If I remove a single line of
code in a function such as a comparison, the program may go into this
infinite exception loop. If I remove a line of code else where, the
tasks may return that they have started, but the tasks don't actually
start running (I added some diag code to show me when the actual task
function is entered). I add a line of code somewhere else, such as a
cout, ant the program runs fine. It may have something to do with the
linking, causing the code to jump to an incorrect address.
Joel Sherrill wrote:
>Angelo Fraietta wrote:
>>I forgot to say I am using pc386dx bsp
>>>What could be causing an exception 6. I have looked in cpu.h and it
>>>saya it is an illegal instruction.
>>>What causes this type of fault?
>I think this means invalid instruction which likely means you have
>corrupt code or jumped somewhere wrong.
>Was the reported address inside or outside your program?
>>Angelo Fraietta
>>PO Box 859
>>Hamilton NSW 2303
>>Home Page
>>http://www.users.bigpond.com/angelo_f/
>>There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
>>There are those who seek knowledge to be known by others - that is VANITY
>>There are those who seek knowledge in order to serve - that is LOVE
>> Bernard of Clairvaux (1090 - 1153)
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
URL: <http://lists.rtems.org/pipermail/users/attachments/20020415/61d5da96/attachment-0001.html>
