Exception 6
Angelo Fraietta angelo_f at bigpond.com
Sun Apr 14 23:51:40 UTC 2002
I am almost dead sure that this is the case now. I had an original bit
of code that went
                    if(pMidiOut[dev_num])
                            pMidiOut[dev_num]->SetTxReady(false);
                    if ((io_in_data & DIAG_MESSAGE_MASK) ==
DIAG_MESSAGE_MASK)
and it crashed big time.
I changed the code to
        if ((io_in_data & DIAG_MESSAGE_MASK) == DIAG_MESSAGE_MASK)
            .... etc
        else
            .... etc
and it worked fine. So I believe it is definitely something to do with
the alignment of the code.
Angelo Fraietta wrote:
> The problem is still there, however, the results vary depending upon
> what I do within the code. I believe that it has something to do with
> the way the code is packed and aligned. If I remove a single line of
> code in a function such as a comparison, the program may go into this
> infinite exception loop. If I remove a line of code else where, the
> tasks may return that they have started, but the tasks don't actually
> start running (I added some diag code to show me when the actual task
> function is entered). I add a line of code somewhere else, such as a
> cout, ant the program runs fine. It may have something to do with the
> linking, causing the code to jump to an incorrect address.
>>>I forgot to say I am using pc386dx bsp
>>>>What could be causing an exception 6. I have looked in cpu.h and it
>>>>saya it is an illegal instruction.
>>>>What causes this type of fault?
>>I think this means invalid instruction which likely means you have
>>corrupt code or jumped somewhere wrong.
>>Was the reported address inside or outside your program?
>>>Angelo Fraietta
>>>PO Box 859
>>>Hamilton NSW 2303
>>>Home Page
>>>http://www.users.bigpond.com/angelo_f/
>>>There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
>>>There are those who seek knowledge to be known by others - that is VANITY
>>>There are those who seek knowledge in order to serve - that is LOVE
>>>    Bernard of Clairvaux (1090 - 1153)
>Angelo Fraietta
>PO Box 859
>Hamilton NSW 2303
>Home Page
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
URL: <http://lists.rtems.org/pipermail/users/attachments/20020415/6cbe0b4d/attachment-0001.html>
