Problems installing gdb-bdm
Claudio Imberlina imberlina at arnet.com.ar
Tue Apr 30 00:37:13 UTC 2002
I am using a Pentium II 350M machine, running Red Hat Linux 7.2, kernel 2.4.7-10.
I am trying to connect bdm to a 68en360 board very similar to an ACE360 ( similar hardware, local made )
I use this board with bdm of SDS cross- development tools ( SDS on-chip v7.0) and everything work OK, also with P&E tools.
The ICD cable from P&E is revision B.
I am migrating to Linux and using gdb-bdm-20020212
I installed the software acording with the install instruction in the package.
I installed the bdm driver, making ( make; make install ) from the linux-old directory, depmod complain, but I can isnmod bdm.
I installed the devs, with local_scripts/MAKEDEV, and this is the result of : ls -l /dev/bdm*
crw-rw-rw-    1    root    root    34,    4    Apr    29    21:03    /dev/bdmcf0
crw-rw-rw-    1    root    root    34,    5    Apr    29    21:03    /dev/bdmcf1
crw-rw-rw-    1    root    root    34,    6    Apr    29    21:03    /dev/bdmcf2
crw-rw-rw-    1    root    root    34,    0    Apr    29    21:03    /dev/bdmcpu320
crw-rw-rw-    1    root    root    34,    1    Apr    29    21:03    /dev/bdmcpu321
crw-rw-rw-    1    root    root    34,    2    Apr    29    21:03    /dev/bdmcpu322
crw-rw-rw-    1    root    root    34,    8    Apr    29    21:03    /dev/bdmicd0
crw-rw-rw-    1    root    root    34,    9    Apr    29    21:03    /dev/bdmicd1
crw-rw-rw-    1    root    root    34,  10    Apr    29    21:03    /dev/bdmicd2
When I test the driver with : ./chk /dev/bdmcpu321 this is the result
Driver Ver :    2.8
Procesor :    CPU32
Interface :    Eric's CPU32
Target status :   0x4    -- NOT RESET, NOT HALTED, STOPPED, POWER ON, CONNECTED
Register test,    1 of 1 :
D00 :
Write Register failed : Invalid target command
When I try with : ./chk /dev/bdmicd1, the result is
open failed : BDM not open
  ----- Original Message -----
  To: Claudio Imberlina
  Cc: rtems-users at oarcorp.com
  Sent: Monday, April 29, 2002 10:40 AM
  Subject: Re: Problems installing gdb-bdm
  On Monday, April 29, 2002, at 05:02 AM, Claudio Imberlina wrote:
    Hello,
     I was trying to install gdb-bdm and gdb-5.0. I have problem installing =
    gdb-5.0, after patching with gdb-bdm, the make file complain for a =
    directory "BDM" ( -lBDM ), and cannot complete the installation.
    When I installed gdb-bdm ( I am using an ICD cable ), during the =
    installation everything was OK, but when I try to check the driver as =
    root with ./chk /dev/bdmicd1 ( on LPT2 ) it complain about BDM not open, =
    when I use /dev/bdmcpu321, it comunicate with the board but it can not =
    test the registers and storp after D00, an emit a message like =
    debugFlag.
    Any Idea, I will apreciate very much your help
  What do you see when you type
  ls -l /dev/bdmicd1
  Eric Norum <eric.norum at usask.ca>
  Department of Electrical Engineering
  University of Saskatchewan
  Saskatoon, Canada.
  Phone: (306) 966-5394 FAX: (306) 966-5407
URL: <http://lists.rtems.org/pipermail/users/attachments/20020429/ba832460/attachment-0001.html>
