Problems installing gdb-bdm
Eric Norum e.norum at sk.sympatico.ca
Mon Apr 29 13:40:48 UTC 2002
On Monday, April 29, 2002, at 05:02 AM, Claudio Imberlina wrote:
> Hello,
>  I was trying to install gdb-bdm and gdb-5.0. I have problem
> installing =
> gdb-5.0, after patching with gdb-bdm, the make file complain for a =
> directory "BDM" ( -lBDM ), and cannot complete the installation.
> When I installed gdb-bdm ( I am using an ICD cable ), during the =
> installation everything was OK, but when I try to check the driver as =
> root with ./chk /dev/bdmicd1 ( on LPT2 ) it complain about BDM not
> open, =
> when I use /dev/bdmcpu321, it comunicate with the board but it can not =
> test the registers and storp after D00, an emit a message like =
> debugFlag.
> Any Idea, I will apreciate very much your help
What do you see when you type
	ls -l /dev/bdmicd1
Eric Norum <eric.norum at usask.ca>
Department of Electrical Engineering
University of Saskatchewan
Saskatoon, Canada.
Phone: (306) 966-5394   FAX:   (306) 966-5407
Name: not available
Type: text/enriched
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20020429/8b632631/attachment-0001.bin>
