DOSFS and libblock
Angelo Fraietta
angelo_f at bigpond.com
Tue Aug 13 03:38:31 UTC 2002
I am unable to make this build. I have two errors occurring that I
cannot get around.
I will explain what I am trying to do first. I am trying to build a
small app that uses the four files that are in
rtems-ss-20020807\cpukit\libblock and seeing if it will run on my
pc386dx build
The first problem I am getting is I get an error that reference 2 of
function _CORE_mutex_Initialize is incompatible in the following
function (I can't see why though) in module bdbuf.c
static inline void
bdbuf_initialize_transfer_sema(bdbuf_buffer *bd_buf)
CORE_mutex_Attributes mutex_attr;
mutex_attr.lock_nesting_behavior = CORE_MUTEX_NESTING_BLOCKS;
mutex_attr.only_owner_release = FALSE;
mutex_attr.discipline = CORE_MUTEX_DISCIPLINES_FIFO;
mutex_attr.priority_ceiling = 0;
_CORE_mutex_Initialize(&bd_buf->transfer_sema,
&mutex_attr, CORE_MUTEX_LOCKED);
If I comment the function out (i.e. _CORE_mutex_Initialize), I get two
unresolved externals:
rtems_ramdisk_configuration_size and rtems_ramdisk_config
I have done a grep through the entire snapshot and cannot find where
these two variables are defined.
Eugeny S. Mints wrote:
>>Does the IDE driver work for the pc386 derivatives in the current snapshot?
>It doesn't - the implementation is hardcoded for powerpc. But you can
>port it to pc386 with minimum changes, I think. But unfortunately current
>IDE driver implementation have architecture which is hard to extend.
>We propose the following architecture:
>generic ATA driver (chip and CPU independant; only implementation of ATA
>standart) locates in c/src/exec/libblock (although I'm not absolute sure
>about this - may be another directory may be more appropriate)
>generic IDE controllers driver and particular drivers for standart ide
>controller chips locate in c/src/libchip/ide
>if ide capacity is integrated into CPU then drivers for such ide locate in
>c/src/lib/libcpu/myCPU
>and if ide controller is somthing custom (for example on FPGA) then
>driver for it goes to c/src/lib/libbsp/myBSP
>Such architecture allows, for example, simply start IDE for any target
>board - just implement particular on-board IDE controller driver and go
>on.
>Currently I've done most part of the work. Because of this I don't think
>that port of Linux driver is necessary now (but of course, than more
>activities then better :)). Also license difference also need attention.
>Regards,
> Eugeny
>>Joel Sherrill wrote:
>>>"Eugeny S. Mints" wrote:
>>>>Angelo,
>>>>On Fri, 19 Jul 2002, Angelo Fraietta wrote:
>>>>>Is this ready yet?
>>>>Currently I'm working on the another implementation of ATA
>>>>driver which is a bit more chip(I mean IDE
>>>>controllers)/CPU independant than thye implementation
>>>>provided
>>>>by Thomas Doerfler. Currently it will be PIO mode
>>>>implementation but both poll and interrupt driven. Also
>>>>architecture of the driver will allow easy extention for
>>>>any IDE controller and for DMA mode. I've already have successful mount of
>>>>msdos partition on real IDE hard disk and successful read of a file.
>>>>I hope I will able to provide something stable (more or
>>>>less) by the end of the next week.
>>>At least the last (broken) snapshot had Thomas' driver in it.
>>>I think the source for everything libblock, libfs, and IDE driver
>>>was up to date in there minus unsubmitted code like Eugeny is
>>>mentioning.
>>>>Regards,
>>>> Eugeny
>>>>>root wrote:
>>>>>>Thomas Doerfler wrote:
>>>>>>>Hi to all,
>>>>>>>a collegue of me has coded a ATA/IDE driver, we
>>>>>>>are currently busy testing it. We found some
>>>>>>>problems in the libblock/libdosfs, but the code
>>>>>>>is getting better every day :-)
>>>>>>>So I guess in one or two weeks we have a code
>>>>>>>ready to be published.
>>>>>>Need I say more than YEAH!!! Thomas did you look
>>>>>>at the DOS FS test that is in GNATS for inclusion
>>>>>>in the test suites?
>>>>>>FYI I have been out of town for 4 days and the modem
>>>>>>would not connect. I have 1200 messages in my inbox and
>>>>>>am just now wading through them. Forgive me if I miss
>>>>>>something. :(
>>>>>>--joel
>>>>>>>Bye,
>>>>>>> Thomas.
>>>>>>>>So it still needs to have an ATAPI driver written for it?
>>>>>>>>>Angelo,
>>>>>>>>>This is our test suit in attachment.
>>>>>>>>>But please take into account that currently there is no any
>>>>>>>>>IDE driver in RTEMS for any BSP. We use gdb simulator and
>>>>>>>>>RAM disk driver which we've developed (it locates in
>>>>>>>>>libblock also) for test purposes.
>>>>>>>>>But it seems somebody called Camilo Alejandro Arboleda as a
>>>>>>>>>person who is working on floppy driver.
>>>>>>>>>Please, feel free ask any question you have,
>>>>>>>>>Regards,
>>>>>>>>> Eugeny
>>>>>>>>Angelo Fraietta
>>>>>>>>PO Box 859
>>>>>>>>Hamilton NSW 2303
>>>>>>>>Home Page
>>>>>>>>http://www.users.bigpond.com/angelo_f/
>>>>>>>>There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
>>>>>>>>There are those who seek knowledge to be known by others - that is VANITY
>>>>>>>>There are those who seek knowledge in order to serve - that is LOVE
>>>>>>>> Bernard of Clairvaux (1090 - 1153)
>>>>>>>IMD Ingenieurbuero fuer Microcomputertechnik
>>>>>>>Thomas Doerfler Herbststrasse 8
>>>>>>>D-82178 Puchheim Germany
>>>>>>>email: Thomas.Doerfler at imd-systems.de
>>>>>>>PGP public key available at: http://www.imd-
>>>>>>>systems.de/pgp_key.htm
>>>>Eugeny S. Mints
>>>>OKTET Ltd.
>>>>1 Ulianovskaya st., Petergof, St.Petersburg, 198904 Russia
>>>>Phone: +7(812)428-4384 Fax: +7(812)327-2246
>>>>mailto:Eugeny.Mints at oktet.ru
>>Angelo Fraietta
>>PO Box 859
>>Hamilton NSW 2303
>>Home Page
>Eugeny S. Mints
>OKTET Ltd.
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
URL: <http://lists.rtems.org/pipermail/users/attachments/20020813/77a1ec19/attachment.html>
