DOSFS and libblock
Angelo Fraietta
angelo_f at bigpond.com
Thu Aug 15 03:41:19 UTC 2002
I have two questions
I haven't actually installed the latest snapshot because I remember
reading that it was broken. If I was to install it, how do I apply the
patches you have given me.
the init_ide function: what is it actually doing? Is it sending a reset
or something to the IDE? What is it supposed to do?
Thomas Doerfler wrote:
>Hello Angelo,
>I have once written a small README for our ide driver, and I
>looked for it (and the ide driver itself)in the current RTEMS
>CVS, but it seems it is either gone or has never been
>included. Therefore I send you the corresponding archive with
>the IDE driver and the README. In the README, there are some
>lines of code from our test application, showing how to
>integrate our IDE driver.
>At a second glance, one step is missing in the README: the
>driver table. So you should add the following lines aswell to
>your "init" module:
>#define CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
>rtems_driver_address_table Device_drivers[] =
> CONSOLE_DRIVER_TABLE_ENTRY
> ,CLOCK_DRIVER_TABLE_ENTRY
> ,IDE_0_DRIVER_TABLE_ENTRY
>wkr,
> Thomas Doerfler.
>>Do you have a small demo app that mounts an IDE drive and maybe reads
>>from a file? I can make the changes to run on the pc386 from there.
>>>Hello Angelo,
>>>>I am unable to make this build. I have two errors occurring that I
>>>>cannot get around.
>>>>I will explain what I am trying to do first. I am trying to build a
>>>>small app that uses the four files that are in
>>>>rtems-ss-20020807\cpukit\libblock and seeing if it will run on my
>>>>pc386dx build
>>>I did not work yet with that snapshot, so my answers will not
>>>be quite precise in some parts...
>>>>The first problem I am getting is I get an error that reference 2 of
>>>>function _CORE_mutex_Initialize is incompatible in the following
>>>>function (I can't see why though) in module bdbuf.c
>>>I have no idea, whta is wrong there, sorry...
>>>>If I comment the function out (i.e. _CORE_mutex_Initialize), I get two
>>>>unresolved externals:
>>>>rtems_ramdisk_configuration_size and rtems_ramdisk_config
>>>You must create these two variables in your "init" module to
>>>specify the number of ramdisks to be created and the
>>>size/characteristics of these disks. The declaration for the
>>>structure of "rtems_ramdisk_configuration" is in "ramdisk.h".
>>>You should only need these variables when you actually use
>>>ramdisks, so I guess you call some kind of initialization
>>>function or a RAMDISK entry in your device driver table.
>>>I hope this helps...
>>>Thomas.
>>>>I have done a grep through the entire snapshot and cannot find where
>>>>these two variables are defined.
>>>>Eugeny S. Mints wrote:
>>>>>>Does the IDE driver work for the pc386 derivatives in the current snapshot?
>>>>>It doesn't - the implementation is hardcoded for powerpc. But you can
>>>>>port it to pc386 with minimum changes, I think. But unfortunately current
>>>>>IDE driver implementation have architecture which is hard to extend.
>>>>>We propose the following architecture:
>>>>>generic ATA driver (chip and CPU independant; only implementation of ATA
>>>>>standart) locates in c/src/exec/libblock (although I'm not absolute sure
>>>>>about this - may be another directory may be more appropriate)
>>>>>generic IDE controllers driver and particular drivers for standart ide
>>>>>controller chips locate in c/src/libchip/ide
>>>>>if ide capacity is integrated into CPU then drivers for such ide locate in
>>>>>c/src/lib/libcpu/myCPU
>>>>>and if ide controller is somthing custom (for example on FPGA) then
>>>>>driver for it goes to c/src/lib/libbsp/myBSP
>>>>>Such architecture allows, for example, simply start IDE for any target
>>>>>board - just implement particular on-board IDE controller driver and go
>>>>>on.
>>>>>Currently I've done most part of the work. Because of this I don't think
>>>>>that port of Linux driver is necessary now (but of course, than more
>>>>>activities then better :)). Also license difference also need attention.
>>>>>Regards,
>>>>> Eugeny
>>>>>>Joel Sherrill wrote:
>>>>>>>"Eugeny S. Mints" wrote:
>>>>>>>>Angelo,
>>>>>>>>On Fri, 19 Jul 2002, Angelo Fraietta wrote:
>>>>>>>>>Is this ready yet?
>>>>>>>>Currently I'm working on the another implementation of ATA
>>>>>>>>driver which is a bit more chip(I mean IDE
>>>>>>>>controllers)/CPU independant than thye implementation
>>>>>>>>provided
>>>>>>>>by Thomas Doerfler. Currently it will be PIO mode
>>>>>>>>implementation but both poll and interrupt driven. Also
>>>>>>>>architecture of the driver will allow easy extention for
>>>>>>>>any IDE controller and for DMA mode. I've already have successful mount of
>>>>>>>>msdos partition on real IDE hard disk and successful read of a file.
>>>>>>>>I hope I will able to provide something stable (more or
>>>>>>>>less) by the end of the next week.
>>>>>>>At least the last (broken) snapshot had Thomas' driver in it.
>>>>>>>I think the source for everything libblock, libfs, and IDE driver
>>>>>>>was up to date in there minus unsubmitted code like Eugeny is
>>>>>>>mentioning.
>>>>>>>>Regards,
>>>>>>>> Eugeny
>>>>>>>>>>>Hi to all,
>>>>>>>>>>>a collegue of me has coded a ATA/IDE driver, we
>>>>>>>>>>>are currently busy testing it. We found some
>>>>>>>>>>>problems in the libblock/libdosfs, but the code
>>>>>>>>>>>is getting better every day :-)
>>>>>>>>>>>So I guess in one or two weeks we have a code
>>>>>>>>>>>ready to be published.
>>>>>>>>>>Need I say more than YEAH!!! Thomas did you look
>>>>>>>>>>at the DOS FS test that is in GNATS for inclusion
>>>>>>>>>>in the test suites?
>>>>>>>>>>FYI I have been out of town for 4 days and the modem
>>>>>>>>>>would not connect. I have 1200 messages in my inbox and
>>>>>>>>>>am just now wading through them. Forgive me if I miss
>>>>>>>>>>something. :(
>>>>>>>>>>--joel
>>>>>>>>>>>Bye,
>>>>>>>>>>> Thomas.
>>>>>>>>>>>>So it still needs to have an ATAPI driver written for it?
>>>>>>>>>>>>>Angelo,
>>>>>>>>>>>>>This is our test suit in attachment.
>>>>>>>>>>>>>But please take into account that currently there is no any
>>>>>>>>>>>>>IDE driver in RTEMS for any BSP. We use gdb simulator and
>>>>>>>>>>>>>RAM disk driver which we've developed (it locates in
>>>>>>>>>>>>>libblock also) for test purposes.
>>>>>>>>>>>>>But it seems somebody called Camilo Alejandro Arboleda as a
>>>>>>>>>>>>>person who is working on floppy driver.
>>>>>>>>>>>>>Please, feel free ask any question you have,
>>>>>>>>>>>>>Regards,
>>>>>>>>>>>>> Eugeny
>>>>>>>>>>>>Angelo Fraietta
>>>>>>>>>>>>PO Box 859
>>>>>>>>>>>>Hamilton NSW 2303
>>>>>>>>>>>>Home Page
>>>>>>>>>>>>http://www.users.bigpond.com/angelo_f/
>>>>>>>>>>>>There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
>>>>>>>>>>>>There are those who seek knowledge to be known by others - that is VANITY
>>>>>>>>>>>>There are those who seek knowledge in order to serve - that is LOVE
>>>>>>>>>>>>Bernard of Clairvaux (1090 - 1153)
>>>>>>>>>>>IMD Ingenieurbuero fuer Microcomputertechnik
>>>>>>>>>>>Thomas Doerfler Herbststrasse 8
>>>>>>>>>>>D-82178 Puchheim Germany
>>>>>>>>>>>email: Thomas.Doerfler at imd-systems.de
>>>>>>>>>>>PGP public key available at: http://www.imd-
>>>>>>>>>>>systems.de/pgp_key.htm
>>>>>>>>Eugeny S. Mints
>>>>>>>>OKTET Ltd.
>>>>>>>>1 Ulianovskaya st., Petergof, St.Petersburg, 198904 Russia
>>>>>>>>Phone: +7(812)428-4384 Fax: +7(812)327-2246
>>>>>>>>mailto:Eugeny.Mints at oktet.ru
>>>>>>Angelo Fraietta
>>>>>>PO Box 859
>>>>>>Hamilton NSW 2303
>>>>>>Home Page
>>>>>Eugeny S. Mints
>>>>>OKTET Ltd.
>>>>Angelo Fraietta
>>>>PO Box 859
>>>>Hamilton NSW 2303
>>>>Home Page
>>Angelo Fraietta
>>PO Box 859
>>Hamilton NSW 2303
>>Home Page
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
URL: <http://lists.rtems.org/pipermail/users/attachments/20020815/71a97381/attachment-0001.html>
