Any news on GCC 3+ and GNAT/RTEMS?
VALETTE Eric valette at crf.canon.fr
Thu Aug 22 09:43:07 UTC 2002
Ralf Corsepius wrote:
>>So first question that comes in mind and make be inrelevant : do you
>>have specific rtems patch for the autoconf or automake software
> No.
OK.
> It basically is the standard procedure to install the packages, ie.
> cd <somewhere>
> tar xzvf autoconf-2.52.tar.gz
> cd autoconf-2.52
> ./configure --prefix=/opt/rtems
> make install
That for sure I know how to do that :-)
> The rpm.specs add some "nice-to-have" convenience stuff to these
> packages (man-page generation etc.), but this is not necessary for
> proper operation. The sequence above should be sufficient.
OK.
>>Next question is what are the command you have documented supposed to do
>>(if I have no rpm command, I must make it differently and understand
>>what really needs to be done).
> I don't fully understand your question, but you seem to be asking what
> the "cd scripts; ./configure ... etc." I described in my previous mail
> does.
Exactly what you typed : the regular configure, make, make install with
only the prefix command and no specific target/specific configure
options for rtems nor patch to the sources...
Thanks a lot. I should be able to build rtems this afternoon. I will
report sucess (I hope) or error to let you know.
Have a nice day,
    __
   /  `                          Eric Valette - Canon CRF
  /--   __  o _.                 Product Dev. Group Software Team Leader
(___, / (_(_(__                 Rue de la touche lambert
                                 35517 Cesson-Sevigne  Cedex
                                 FRANCE
Tel: +33 (0)2 99 87 68 91       Fax: +33 (0)2 99 84 11 30
E-mail: valette at crf.canon.fr    http://www.crf.canon.fr
