non-maskable interrupt
Fri Dec 6 16:32:55 UTC 2002
Ilya Alexeev wrote:
> Hi all.
> I am using rtems-ss-20020301 and gen68360 bsp.
I think this is the problem that tracked and fixed as PR267.  It
was a bug in m68k/cpu_asm.S where it was not incrementing
_ISR_Nest_level
which violates the Watchdog* routines assumptions about knowing
when an ISR happened.
THe ChangeLog entry says it was fixed in August.  So anything newer
than that has the fix.  CHeck out CVSweb to see what the change was
or grab a newer version.
> My MC68360 board has external device which uses
> non-maskable Level 7 Interrupt Autovector.
> RTEMS documentation says that it is OK to use non-maskable ISRs,
> but they are must not use system calls.
> My ISR doen't use any system calls,
> it just read/write a registers of external device,
> but there are some problems then this ISR called too often.
> This ISR spoils some RTEMS internal data structures.
> I have add a number of test tasks for my application,
> which are just call rtems_task_wake_after(1).
> Then I call the ISR enough often,
> my system hangs somewhere in RTEMS' _Watchdog* routines...
> What I am doing wrong?
> Is it possible to correctly use non-maskable ISR in RTEMS?
> And one more thing - I am using standart call - rtems_interrupt_catch
> for attaching non-maskable ISR.. Is it OK?
> I will be grateful for any help.
> Ilya V. Alexeev
> ilya at continuum.ru
> Continuum Plus JSC
> Yaroslavl, Russia
> Phone: (+7)0852 240200
> Fax:   (+7)0852 359977
