AW: Booting RTEMS PC386 via dos prompt
Angelo Fraietta
angelo_f at bigpond.com
Tue Dec 10 21:29:48 UTC 2002
John Bebbington wrote:
><snip>
>>Thanks Luca,
>>I want to tell you that the modified x.exe works just fine on the target.
>>I would like to ask you if I could send our e-mail correspondence to a
>>users-group called rtems-users at oarcorp.com. There
>>are some people there who would be interested in:
>>1) the eXtender allowing rtems programs to boot directly from dos.
>>2) the minimal stack problem and the proposed solution to in-line the
>>prerequite code before stack establishment.
>>3) when the new version of the eXtender.exe with minimal stack will be
>>available on your web-site for download.
>>thanks again for providing this feature.
>>regards
>>John Bebbington.
This sounds great!!
>Luca wrote:
>I am more than happy to see people that are willing to use x.exe,
>and if it can be useful to someone I am willing to help as much as I can.
>>There are some people there who would be interested in:
>Good. In my experience, the eXtender can speed-up the development and
>testing
>process (if the rtems application does not corrupt dos memory, when it
>finishes it can simply return to DOS, without rebooting the system).
This does not really concern me as I would only like to Run a DOS
program first (to check the serial port for a new RTEMS exe to be
written to hard drive) and then boot to RTEMS until machine is turned
off. i.e. Never return to DOS.
I could probably do this via autoexec.bat?
>I think it will be available in 2 days or 3. Unfortunately, I am finishing
>my PhD, and I can work on the eXtender only in my spare time... I am just
>finishing to review the changes that I made, and after that I'll release the
>new version. Since I did some other changes in ELF parsing, I'll probably
>need your help to test the new version before releasing it...
So what would be required on our part to test this?
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
Bernard of Clairvaux (1090 - 1153)
URL: <http://lists.rtems.org/pipermail/users/attachments/20021211/0fd3fbf4/attachment.html>
