multiprocessor architecture...2
Wed Dec 11 16:58:47 UTC 2002
Francesco Poletti wrote:
> Sorry Joel, I was looking for some architecture suggestion: my simulator
> is under development and I don't know which is best way to implement the
> mechanism by which a processore may be able to interrupt another. I
> don't know which are architectural possibility...If anyone may suggest
> me where I can find documentation.
Three possibilities I know of.. others probably exist:
 + poll
 + board feature for in inter-board interrupt.  I know the Motorola
   VME m68k boards tended to have this feature as did other vendors.
 + CPU feature.  The hppa had an interprocessor bus for SMP boards.
   Based upon the "node number" in the system (hardcoded), each
   CPU had some MP communications registers at a certain address.
   These included this type of interrupt.  This is the only CPU RTEMS
   has been ported to that I know has this type of feature.
Your simulator has to simulate a CPU and its external peripherals to
provide a complete -- if simple -- system.
Is that more what you were looking for?
> Francesco
> > > Hy, I'm developing a multi arm simulator which one day... will be
> boot
> > > with rtems.
> > > When I read the shared memory code I saw that may be important for
> the
> > > comunication between processor which one node will able to interrupt
> > > another node. In my simulator this thing isn't implemented and I'm
> > > asking which way may be more coorect...I'm looking for documentation
> but
> > > I don't find anything interesting.
> > Not surprising as this is a shared memory driver specific question.
> > It supports using either interrupts between the boards or installing a
> > routine that is called on each clock tick to poll for new packets.
> > This is configurable on a per BSP basis via the shmconfig support.
> > [NOTE: The shared memory driver predates the Classic API timer
> > manager.  It really should use the timer manager for its polling
> > routine instead of the clock tick trick it is currently using.]
> > > Thanks to anyone which can help me.
> > > Francesco.
> > Joel Sherrill, Ph.D.             Director of Research & Development
> > joel at OARcorp.com                 On-Line Applications Research
> > Ask me about RTEMS: a free RTOS  Huntsville AL 35805
> > Support Available                (256) 722-9985
