RTEMS gdb script
Till Straumann strauman at SLAC.Stanford.EDU
Wed Dec 11 22:57:30 UTC 2002
Joel.
It would be nice to have these (and more) in the system itself
(so I could call them from CEXP).
-- Till
Joel Sherrill wrote:
> Hi,
> I have mentioned this a few times over the years but
> it never seems to get anywhere.  Attached is a gdb script
> I conjured up a while back to define macro commands for
> gdb that dump some internal RTEMS structures in a meaningful
> way.
> It is a hack in process.  The top is a bunch of directory
> commands to point back to the source tree I was using
> at the time.
> The commands of interest are:
>   dump_tasks	   - prints classic API tasks
>   dump_pthread	   - prints pthreads
>   dump_all_tasks   - prints internal, classic, and pthreads
>   dump_ticks_chain - prints ticks chain (ISR serviced watchdog timers)
>   dumps_ticks_tasks_chain - print ticks chain (task serviced watchdog
> timers)
> I am throwing this out for a handful of reasons.
>   1.  It needs feedback.
>   2.  The command names are VERY bad!  Suggestions desired.
>   3.  More commands are needed.  These are good examples for
>       creating ones that run the other object chains.
>   4.  Now they are in the mailing list archive so I won't
>       misplace them again. :)
> Ideally I would like to see a robust set of these commands
> defined from a user's point of view.  Then we could add them
> as "not implemented" and everyone could write them as needed.
> These run as macros in gdb so in theory are pretty target
> independent.  You have to source this file to get the commands.
> Feedback, comments welcomed.
> --joel
> directory /usr1/rtems/work/rtems/c/src/exec/rtems/src
> directory /usr1/rtems/work/rtems/c/src/exec/posix/src
> directory /usr1/rtems/work/rtems/c/src/exec/sapi/src
> directory /usr1/rtems/work/rtems/c/src/exec/score/src
> directory /usr1/rtems/work/rtems/c/src/exec/score/cpu/powerpc
> directory /usr1/rtems/work/rtems/c/src/lib/libbsp/powerpc/psim/clock
> directory /usr1/rtems/work/rtems/c/src/lib/libbsp/powerpc/psim/startup
> directory /usr1/rtems/work/rtems/c/src/lib/libbsp/shared
> directory /opt/gnatrtems/powerpc-rtems/psim/lib/include/rtems/score
> directory /opt/gnatrtems/powerpc-rtems/psim/lib/include/rtems/rtems
> define dump_tasks_support
>   set $index = 1
>   while $index <= $arg0.maximum
>     set $pt = (Thread_Control *)$arg0.local_table[$index]
>     if $pt != 0
>       printf "thread 0x%x: state=0x%x pri=%d ", \
>         $pt->Object.id, $pt->current_state, $pt->current_priority
>       printf "ticks_executed=%d \n", $pt->ticks_executed
>     end
>     set $index = $index + 1
>   end
> end
> define dump_internal_tasks
>   dump_tasks_support  _Thread_Internal_information
> end
> define dump_tasks
>   dump_tasks_support  _RTEMS_tasks_Information
> end
> define dump_pthread
>   dump_tasks_support  _POSIX_Threads_Information
> end
> define dump_all_tasks
>   printf "Executing: 0x%x, Heir: 0x%x\n", _Thread_Executing->Object.id, \
>     _Thread_Heir.Object.id
> end
> define dump_watchdog_chain
>   set $permt = &$arg0.permanent_null
>   set $node = $arg0.first
>   while $node != $permt
>    set $wnode = (Watchdog_Control *)$node
>    #printf "0x%x, %d, 0x%x -- ", $wnode, $wnode.delta_interval, $wnode.routine
>    printf "======================\n"
>    print $wnode
>    print *$wnode
>    set $node = $node.next
>   end
> end
> define dump_ticks_chain
>   dump_watchdog_chain _Watchdog_Ticks_chain
> end
> define dump_ticks_task_chain
>   dump_watchdog_chain _Timer_Ticks_chain
> end
> #d
> #b _Thread_Delay_ended
> #r
