RTEMS gdb script
Chris Johns cjohns at cybertec.com.au
Wed Dec 11 23:41:18 UTC 2002
Till Straumann wrote:
> It would be nice to have these (and more) in the system itself
> (so I could call them from CEXP).
Can CEXP call the existing monitor commands ?
If it did then you can then see some of these things. Plus you can use the Capture
Engine CLI. Being able to trace the task switches of a running system has been rather
useful. Found a few things happening that I did not know about or expect. Also
running the "ctload", a mini top is fun.
  Chris Johns, cjohns at cybertec.com.au
