rtems_task_mode
Mon Dec 16 03:13:45 UTC 2002
>   Hi, all
>         I've some trouble with rtems_task_mode. In the RTEMS C User's Guide, it is said that the directive can obtain or change only current task's mode. So is there a RTEMS api can manipulate other task's mode?
>         Thanks to anyone who give your advice.
The current rtems_task_mode directive is based upon the
RTEMS/ORKID API specification.
A simple way would be to make the current one a wrapper for another that
worked on any task ID.
