rtems_task_mode
Scott J scott.j at myrealbox.com
Mon Dec 16 03:19:31 UTC 2002
	Thanks Joel, so there isn't a simple way to manipulate other task's mode at present, maybe I should give up my idea about this. Thanks again :)
>>   Hi, all
>>         I've some trouble with rtems_task_mode. In the RTEMS C User's Guide, it is said that the directive can obtain or change only current task's mode. So is there a RTEMS api can manipulate other task's mode?
>>         Thanks to anyone who give your advice.
>The current rtems_task_mode directive is based upon the
>RTEMS/ORKID API specification.
>A simple way would be to make the current one a wrapper for another that
>worked on any task ID.
>Joel Sherrill, Ph.D.             Director of Research & Development
>joel at OARcorp.com                 On-Line Applications Research
>Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>   Support Available             (256) 722-9985
