vxworks module on rtems as application task ?
Salman unix at gofree.indigo.ie
Wed Dec 18 13:08:08 UTC 2002
Hey guys,
I'm not very familiar with vxworks.
does it give you a shell ?
can you insert modules in run-time, remotely ?
anyway, I have came across a driver for a pci card on vxworks here.
I think this is a module, and you're supposed to load it remotely when vxworks is initialized on target.
I believe the following is the function which starts the loading process (i could be wrong).
int init_module(int int_vect)
  taskSpawn("Init",100,0,40000,init_pci,int_vect,NULL,NULL,
		  NULL,NULL,NULL,NULL,NULL,NULL,NULL);
my understanding is that, this just starts a task, which calls init_pci and the rest goes from init_pci.
Is it possible to plug this code into rtems, and instead of vxworks loading it as a module, I load it as one of my tasks in my application program ? (ofcourse at compile time)
does vxworks differ much from rtems ?
can I get a vxworks module on rtems with some fiddling ?
thanks,
Salman
