Success using MSYS... and failure
Steve steved94 at attbi.com
Mon Dec 23 04:52:00 UTC 2002
----- Original Message -----
From: "Paul Whitfield" <paulw at microsol.iinet.net.au>
To: "Steve" <steved94 at attbi.com>
Cc: "rtems-users" <rtems-users at OARcorp.com>
Sent: Sunday, December 22, 2002 8:31 PM
Subject: Re: Success using MSYS... and failure
> Steve wrote:
> > After updating to a newer version of MSYS, the mingw runtime, and the
> > w32api.  I now get much farther with my build.  Now I get an error some
time
> > after entering "make cross":
> It appears that collect2.exe is your problem.
> IIRC: gcc on windows does not use collect2.
> The calls that can not be resolved are unix calls and are not
> available in the MS runtime.
> There may be a work-around for this, you are better off chasing this
> on the MSYS mailing list (which I see you have already posted to
> with an earlier problem).
> Why are you trying to build these for MSYS?
> Why don't you want to use cygwin?
I would eventually like to have a compiler that I can install with no cygwin
in sight.  Perhaps I'm making bad inferences.  Maybe I can build a compiler
on cygwin setting --host=i686-pc-mingw32 with the rtems target.
I guess I hadn't really thought about it.
Perhaps I'll try that.
Thanks,
Steve
(The Duck)
> The RTEMS build environment works really quite
> well under cygwin, and will be easier to build,
> and supported (eventually).
> At least I think that cygwin is still support, is that the
> case Joel or anyone else care to comment?
> Best regards
> Paul
