Bochs
Chris Johns
cjohns at cybertec.com.au
Thu Dec 5 23:27:04 UTC 2002
Chris Caudle wrote:
> >Was this with current RTEMS sources?
> Unlimited test ran. At the very end it has a message about failing creating
> a task because the id already existed. Is that normal? It's been so long
> since I ran the samples I can't remember.
The test should run cleanly. This test can generate strange results if you have other
tasks running.
Could you please post the message and I will take a look.
Chris Johns, cjohns at cybertec.com.au
