AW: Booting RTEMS PC386 via dos prompt
Angelo Fraietta
angelo_f at bigpond.com
Fri Dec 13 05:24:00 UTC 2002
I tested with Bat File on my target system and it worked fine
Angelo Fraietta wrote:
> Luca Abeni wrote:
>>Hi Joel,
>>>When you say "DOS prompt", do you mean just DOS
>>>or could it also be run from the command interpreter
>>>in Windows?
>>The system must be in real mode. So, no Windows, no emm386, etc...
>>I generally use freedos for testing, but msdos (or any other 16 bit
>>*dos) should be ok too.
>> Luca
> I just downloaded and tested using Dr Calderos dos and it worked fine.
> Thanks. :-)
>Angelo Fraietta
>PO Box 859
>Hamilton NSW 2303
>Home Page
>http://www.users.bigpond.com/angelo_f/
>There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
>There are those who seek knowledge to be known by others - that is VANITY
>There are those who seek knowledge in order to serve - that is LOVE
> Bernard of Clairvaux (1090 - 1153)
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
URL: <http://lists.rtems.org/pipermail/users/attachments/20021213/7a632335/attachment-0001.html>
