Success using MSYS... and failure
Steve
steved94 at attbi.com
Mon Dec 23 04:15:53 UTC 2002
After updating to a newer version of MSYS, the mingw runtime, and the
w32api. I now get much farther with my build. Now I get an error some time
after entering "make cross":
gcc -DIN_GCC -DCROSS_COMPILE -g -O2 -W -Wall -Wwrite-strings -Wstrict-prot
otypes -Wmissing-prototypes -Wtraditional -pedantic -Wno-long-long -DHAVE_C
ONFIG_H -o Tcollect2.exe \
collect2.o tlink.o hash.o intl.o underscore.o version.o
./intl/libintl.a ../libiberty/libiberty.a
collect2.o: In function `handler':
C:/msys/1.0/home/steve/rtemsbuild/source/gcc-3.2.1/gcc/collect2.c:461:
undefined reference to `kill'
collect2.o: In function `scan_prog_file':
C:/msys/1.0/home/steve/rtemsbuild/source/gcc-3.2.1/gcc/collect2.c:2107:
undefined reference to `pipe'
C:/msys/1.0/home/steve/rtemsbuild/source/gcc-3.2.1/gcc/collect2.c:2130:
undefined reference to `fork'
make[1]: *** [collect2.exe] Error 1
make[1]: Leaving directory `/home/steve/rtemsbuild/build/gcc/gcc'
make: *** [cross] Error 2
Here is the content of my config.status file:
#!/bin/sh
# This file was generated automatically by configure. Do not edit.
# This directory was configured as follows:
/home/steve/rtemsbuild/source/gcc-3.2.1/configure --with-gcc-version-trigger
=/home/steve/rtemsbuild/source/gcc-3.2.1/gcc/version.c --host=i686-pc-mingw3
2 --verbose --target=i586-rtems --prefix=/gcc-i586-rtems --with-gnu-as --wit
h-gnu-ld --with-newlib --enable-languages=c++,ada --norecursion
# using "mh-frag"
I suspect this error is telling me that either I need to patch the source to
collect.c for a non-unix build, or I have some switch wrong in my configure
command line.
Any hints would be appreciated. Till then I'll keep digging.
Thanks in advance,
Steve
(The Duck)
----- Original Message -----
To: "RTEMS List" <rtems-users at OARcorp.com>
Sent: Friday, December 20, 2002 7:59 PM
Subject: Any success using MSYS?
> Has anyone had any success building gcc-3.2.1 under W2k using MinGW &
MSYS?
> Binutils-2.13.1 with no problems using:
configure --verbose --target=i586-rtems --prefix=/gcc-i586-rtems --with-gnu-
> as --with-gnu-ld
> But when I try to build gcc using
> as --with-gnu-ld --with-newlib
> Configure does ok, but then when I try:\
> make cross
> I get:
> $ make cross
> make[1]: Entering directory `/home/RtemsBuild/build/gcc/libiberty'
> if [ x"" != x ] && [ ! -d pic ]; then \
> mkdir pic; \
> else true; fi
> touch stamp-picdir
> if [ x"" != x ]; then \
gcc -c -DHAVE_CONFIG_H -g -O2 -I. -I../../../source/gcc-3.2.1/libiberty/../i
> nc lude -W -Wall -Wtraditional -pedantic
> ../../../source/gcc-3.2.1/libiberty/rege x.c -o pic/regex.o; \
> else true; fi
> nclu de -W -Wall -Wtraditional -pedantic
> ../../../source/gcc-3.2.1/libiberty/regex.c
> 0 [main] sh 3412 open_stackdumpfile: Dumping stack trace to
> sh.exe.stackdu mp
> make[1]: *** [regex.o] Segmentation fault (core dumped)
> make[1]: Leaving directory `/home/RtemsBuild/build/gcc/libiberty'
> make: *** [all-libiberty] Error 2
> Im on W2k and I'd like to give GNAT/RTEMS a shot.
> Steve
> (The Duck)
