Strange Problem calling chdir()
Peter Mueller
peter.o.mueller at gmx.de
Mon Dec 30 17:47:17 UTC 2002
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi Gregm,
I can debug (step) into chdir().
Peter
On Mon, 30 Dec 2002 11:06:53 -0500 (EST)
gregory.menke at gsfc.nasa.gov wrote:
> Peter Mueller writes:
> > Hash: SHA1
> > Hello all,
> > I have a strange problem with the code shown below. In
> > dummyHMI::test() argc/argv are in reality built from
> > commands/parameters I get from a serial line. The problem is that the
> > name holds "test" as expected in dummyClient::printdir(), but is
> > empty in chdir().
> Barring some subtle bug, my guess is the chdir() is being optimized
> away since you're not doing anything with res. Try declaring res,
> then assigning chdir's return value to it on a separate line.
> Gregm
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.0.7 (GNU/Linux)
iD8DBQE+EIalUzCcwYQMTJoRAnM7AJ48mSG35pUYcbMUhD/G7vj82iOwswCgvkI/
Pb3RwuGKiI9aiKFZY8lg6iI=
=aiMF
-----END PGP SIGNATURE-----
