ARM?
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Feb 1 12:12:20 UTC 2002
jtm at smoothsmoothie.com wrote:
> I'm considering RTEMS for an ARM based board and was wondering how
> complete the ARM support is. I know I'll have to do a BSP, but
> what about basic ARM support? I see a BSP based on the ARM7TDMI;
> will that work on an ARM9 based design without a lot of modifications?
>From RTEMS perspective, the question is what differs between ARM9
and ARM7 for the instruction and register sets. This is primarily
what is managed in score/cpu/arm. Issues like varying on-CPU
interrupt management and cache are addressed in libcpu/arm.
But I don't know offhand what's different at each ARM ISA level
so can't give details. It is usually only a matter of knowing
what differs and addressing that. On other CPU families, we expect
very specific and mostly minor differences.
> Also, what tool configuration should be used to build the arm_bare_bsp
> target? arm-rtems? arm-rtemself?
You should use arm-rtems. If you are on Linux, just grab prebuilt
tools.
If on Cygwin, I posted some tools last week on the ftp site built using
new script I wanted feedback on. Either way, you don't have to build
them. :)
The 2nd question is the BSP. What board are you using? You will
almost certainly have to create a new BSP for it to support its
hardware. It is likely that libchip and other BSPs will have
stuff to help you though.
> Thanks.
> Jay Monkman The truth knocks on the door and you say "Go away, I'm
> monkman at jump.net looking for the truth," and so it goes away. Puzzling.
> - from _Zen_and_the_Art_of_Motorcycle_Maintenance_
joel at OARcorp.com On-Line Applications Research
