ISRs and rtems_task_wake_after
Aaron J. Grier aaron at frye.com
Fri Feb 15 01:02:30 UTC 2002
just a reality check.  I've been banging on the same chunk of code for
two days straight now and I think I finally figured out what I was doing
wrong.
you cannot call rtems_task_wake_after from within an ISR, correct?
IE "never never never block within an ISR" is a rule I should carve into
the top of my monitor so I'm reminded of it every day, yes?
  Aaron J. Grier  |   Frye Electronics, Tigard, OR   |  aaron at frye.com
     "In a few thousand years people will be scratching their heads
       wondering how on earth the first computer was invented and
          bootstrapped without a prior computer to do it with."
                    --  Chris Malcolm, on comp.arch
