RTEMS ss-20020215 available
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Feb 15 14:43:12 UTC 2002
This primarily fixes some build problems discovered in 20020205
such as not completely honoring prefix != /opt/rtems and some
unix build problems. There is also a first cut at a mips gdb
serial stub in libbsp/shared which is designed to integrate into
the RTEMS MIPS exception processing.
joel at OARcorp.com On-Line Applications Research
