Coldfire GDB BDM problem
Bill Butler
billb at tnex.com
Tue Feb 19 17:06:05 UTC 2002
All,
Bill Knight and I are trying to get the GDB/Insight debugger working for
a 5307 coldfire with a P&E wiggler REVA. I am using versions gdb 5.0.
with Chris John's BDM add-ons. This is running on a 1Ghz machine under
Win 2000, with the latest Cygwin environment.
I am able to connect to the MCF5307C3 eval board and do a board setup on
it. I can load a simple App onto it but that is about it. I set the PC
to the start address but the step, step-into,... buttons are grayed out
with only the GO button active. When I go to the console on GDB and try
si, the PC register immediately goes to a flash address (resets).
To Verify that our Debugging platform( PC, Wiggler and Eval Board) works
we have used the WinRiver's singleStep debugger. With it, I am able to
connect to the evaluation board, load an image and step or run with it.
We have tried reducing all the variables in the process we could. I
compiled a simple app (main and one function), compiled it with
m68k-elf-gcc (without rtems patch), used GDB/Insight with only the BDM
patch (no rtems patch) with the same results.
We have even tried to get it working on a Coldfire SBC5206 eval board
with a different wiggler on a different development platform, all with
similar results.
A brief run down of what I have done is.
I modified the setup-CS and Dram (I'm using sdram) routines to map the
board correctly (using a MCF5307C3 eval board). I have verified that I
can modify ram ($0-> 16meg), Mbar is set and working ($10000000), and
Flash code is at $FFFE0000.
In my home directory we have a gdb.ini file (included at bottom of file)
with the GDB routines we use. We are manually invoking them from the
console right now with Initboard5307C3
>From scratch
1) Latching GDB and it does read in the gdb.ini file.
2) Connect to the target (this completes)
3) A GDB console we call InitBoard5307C3
4) Verify register, Mbar, Ram memory. All ok
5) I load a.out (simple test program using m68k-elf-gcc and using
default Crt0)
6) Source window a.out asm (C source never displayed) and code starting
at 0x2000 (proper place)
7) Set the Pc to start(2000)
4) All the step buttons are grayed out.
9) go to console window and type SI
10) Board resets and pc goes back to FFFExxxx
We are stuck.. Does anyone have an idea of what to try next.
PS. I have tried to walk through what is on Fiddles GDB docs using only
the GDB console and it act very similarly when I type SI
Thank you
Bill Butler
INIT file
# GDB Init script for the Coldfire 5207C3 processor on the
# Cybertec SFP single board computer. See :
# http://www.cybertec.com.au/
# Copyright 2001 Cybertec Pty Ltd,
# Chris Johns <cjohns at cybertec.com.au>
# The main purpose of this script is to configure the
# DRAM controller, load code, and set the program counter
# when using Insight.
# Commands to ease the C notation of GDB.
# These command read and write 8, 16 and 32 values.
#source ./5307c3.gdb
# GDB Init script for the Coldfire 5307 processor.
# DRAM controller so code can be loaded.
define setup-simregs
set $mbar = 0x10000001
set $rsr = $mbar - 1 + 0x000
set $sypcr = $mbar - 1 + 0x001
set $swivr = $mbar - 1 + 0x002
set $swsr = $mbar - 1 + 0x003
set $simr = $mbar - 1 + 0x003
set $par = $mbar - 1 + 0x004
set $irqpar= $mbar - 1 + 0x006
set $pllcr = $mbar - 1 + 0x008
set $mpark = $mbar - 1 + 0x00c
set $ipr = $mbar - 1 + 0x040
set $imr = $mbar - 1 + 0x044
set $icr0 = $mbar - 1 + 0x04c
set $icr1 = $mbar - 1 + 0x04d
set $icr2 = $mbar - 1 + 0x04e
set $icr3 = $mbar - 1 + 0x04f
set $icr4 = $mbar - 1 + 0x050
set $icr5 = $mbar - 1 + 0x051
set $icr6 = $mbar - 1 + 0x052
set $icr7 = $mbar - 1 + 0x053
set $icr8 = $mbar - 1 + 0x054
set $icr9 = $mbar - 1 + 0x055
set $csar0 = $mbar - 1 + 0x080
set $csmr0 = $mbar - 1 + 0x084
set $cscr0 = $mbar - 1 + 0x08a
set $csar1 = $mbar - 1 + 0x08c
set $csmr1 = $mbar - 1 + 0x090
set $cscr1 = $mbar - 1 + 0x096
set $csar2 = $mbar - 1 + 0x098
set $csmr2 = $mbar - 1 + 0x09c
set $cscr2 = $mbar - 1 + 0x0a2
set $csar3 = $mbar - 1 + 0x0a4
set $csmr3 = $mbar - 1 + 0x0a8
set $cscr3 = $mbar - 1 + 0x0ae
set $csar4 = $mbar - 1 + 0x0b0
set $csmr4 = $mbar - 1 + 0x0b4
set $cscr4 = $mbar - 1 + 0x0ba
set $csar5 = $mbar - 1 + 0x0bc
set $csmr5 = $mbar - 1 + 0x0c0
set $cscr5 = $mbar - 1 + 0x0c6
set $csar6 = $mbar - 1 + 0x0c8
set $csmr6 = $mbar - 1 + 0x0cc
set $cscr6 = $mbar - 1 + 0x0d2
set $csar7 = $mbar - 1 + 0x0d4
set $csmr7 = $mbar - 1 + 0x0d8
set $cscr7 = $mbar - 1 + 0x0de
set $dcr = $mbar - 1 + 0x100
set $dacr0 = $mbar - 1 + 0x108
set $dmr0 = $mbar - 1 + 0x10c
set $dacr1 = $mbar - 1 + 0x110
set $dmr1 = $mbar - 1 + 0x114
set $tmr1 = $mbar - 1 + 0x140
set $trr1 = $mbar - 1 + 0x144
set $tcr1 = $mbar - 1 + 0x148
set $tcn1 = $mbar - 1 + 0x14C
set $ter1 = $mbar - 1 + 0x151
set $tmr2 = $mbar - 1 + 0x180
set $trr2 = $mbar - 1 + 0x184
set $tcr2 = $mbar - 1 + 0x188
set $tcn2 = $mbar - 1 + 0x18C
set $ter2 = $mbar - 1 + 0x191
set $paddr = $mbar - 1 + 0x244
set $padat = $mbar - 1 + 0x248
end
define setup-cs
set *((short*)$csar0) = 0xffe0
set *((short*)$cscr0) = 0x0d80
set *((long* )$csmr0) = 0x000f0001
set *((short*)$csar1) = 0x0
set *((short*)$cscr1) = 0x0
set *((long* )$csmr1) = 0x0
set *((short*)$csar2) = 0x3000
set *((long* )$csmr2) = 0x00070001
set *((short*)$cscr2) = 0x0100
set *((short*)$csar3) = 0x0
set *((short*)$cscr3) = 0x0
set *((long* )$csmr3) = 0x0
set *((short*)$csar4) = 0x0
set *((short*)$cscr4) = 0x0
set *((long* )$csmr4) = 0x0
set *((short*)$csar5) = 0x0
set *((short*)$cscr5) = 0x0
set *((long* )$csmr5) = 0x0
set *((short*)$csar6) = 0x0
set *((short*)$cscr6) = 0x0
set *((long* )$csmr6) = 0x0
set *((short*)$csar7) = 0x0
set *((short*)$cscr7) = 0x0
set *((long* )$csmr7) = 0x0
set16 $par 0x0008
end
define setup-misc
set *((short*)$icr0) = 0x0
# set *((byte*)$icr1) = 0x0
set *((short*)$icr2) = 0x0
# set *((byte*)$icr3) = 0x0
set *((short*)$icr4) = 0x0
# set *((byte*)$icr5) = 0x0
set *((short*)$icr6) = 0x0
# set *((byte*)$icr7) = 0x0
set *((short*)$icr8) = 0x01E
# set *((byte*)$icr9) = 0x1E
set *((long*)$imr) = 0x0000FFFE
set *((short*)$par) = 0xFFFF
end
define setup-sdram
set *((short*)$dcr) = 0x822a
set *((long* )$dacr0) = 0x00001404
set *((long* )$dmr0) = 0x007c0001
set *((long* )$dacr1) = 0x00801404
set *((long* )$dmr1) = 0x007c0001
end
define initBoard5307C3
setup-simregs
# setup-misc
setup-cs
setup-sdram
end
define set8
set *((unsigned char*) $arg0) = $arg1
end
document set8
Set 8bit memory: set8 ADDRESS VALUE
end
define set16
set *((unsigned short*) $arg0) = $arg1
end
document set16
Set 16bit memory: set16 ADDRESS VALUE
end
define set32
set *((unsigned long*) $arg0) = $arg1
end
document set32
Set 32bit memory: set32 ADDRESS VALUE
end
define d8
x /$arg1b $arg0
end
document d8
Dump 8bit memory: d8 ADDRESS LENGTH
end
define d16
x /$arg1h $arg0
end
document d16
Dump 16bit memory: d16 ADDRESS LENGTH
end
define d32
x /$arg1w $arg0
end
document d32
Dump 32bit memory: d32 ADDRESS LENGTH
end
define uhelp
help user-defined
end
document uhelp
Help those who cannot RTFM such as those hard wary workers amongst us
end
# Dump the exception stack frame.
define dump-exception-sframe
set $frsr = *(unsigned short *)((unsigned long)$sp + 2)
set $frpc = *(unsigned long *)((unsigned long)$sp + 4)
set $frfvo = *(unsigned short *)((unsigned long)$sp + 0)
set $frcode = $frfvo >> 12
set $frvect = ($frfvo & 0xFFF) >> 2
printf "EXCEPTION -- SR:0x%X PC:0x%X FRAME:0x%x VECTOR:%d\n", $frsr,
$frpc, $frcode, $frvect
end
document dump-exception-sframe
Dumps information about an exception stack frame.
end
define setup-and-load
dir .
initBoard5307C3
# load
# set $pc=start
end
# Main, execution starts here.
#target bdm /dev/bdmcf0
#setup-and-load
set print pretty
set print asm-demangle
