Rtems Rebuild Remake Question
Bill Butler billb at tnex.com
Mon Feb 25 23:30:03 UTC 2002
All,
The current build I'm working with was built with --enable-multilib, and
got it to work. After asking how to use this, I was informed it was not
quite ready (and it takes a long time to build), I am moving back to
>configure --target=m68k-rtems --enable-rtemsbsp=sbc5307
--prefix=/opt/rtems
>make all
> make install
But my question is this.
I am tweaking my bsp and adding / deleting files (network) and would
like to know what should be done when changing the makefiles. Currently
I have had to delete the build directory and reconfigure/make.
I tried several things to get the new ...Network/Makefile to move from
the src directory to the build directories. I failed miserable and
deleted the build directory and rebuilt.
Here is what I tried.
> Goal: to NOT use network.c ns8390.c and to USE ne2k.c in BSP.
1) edit src...network\makefile.am reflecting change
2) automake network\Makefile
3) cd to build directory
...getting fussy here
4) make all..??
4a) autoconfig??
Thank you for your help.
Bill Butler
AIPCom Inc
972-644-2328 x16
bbill at tnex.com
