Compilation Problems
Vasudev Mulchandani
vasu at tataelxsi.co.in
Tue Feb 26 13:59:05 UTC 2002
Hello !
I am trying to build rtems and facing some compilation problems
Host: Solaris 8.0 on sparc
Target: i386
my directory structure looks like
% ls
build/ rtems-4.5.0/
% cd build
% ../rtems-4.5.0/c/configure --target=i386-rtems
--enable-rtemsbsp=i386ex --prefix=opt
The configuration is succesful.
% make all
This leads to an error
removing the earlier capture..
checking target's objcopy... (cached) /opt/rtems/bin/i386-rtems-objcopy
checking target's size... (cached) /opt/rtems/bin/i386-rtems-size
checking target's strip... (cached) /opt/rtems/i386-rtems/bin/strip
checking for make/custom/i386ex.cfg... yes
checking for RTEMS_CPU_MODEL...
../../../../../rtems-4.5.0/c/src/lib/libcpu/i386/configure:
../../../../../c/i386ex/make/i386ex.cache: not found
configure: error:
../../../../../rtems-4.5.0/c/src/lib/libcpu/i386/configure failed for
i386
configure: error: ../../../../rtems-4.5.0/c/src/lib/libcpu/configure
failed for libcpu
configure: error: ../../../rtems-4.5.0/c/src/lib/configure failed for
lib
make[1]: *** [i386ex] Error 1
make[1]: Leaving directory `/home/rtems/build'
make: *** [all-recursive] Error 1
Have installed all the gnu tools in /opt
% ls /opt/rtems
bin/ include/ lib/ share/
i386-rtems/ info/ man/
% ls /opt/rtems/bin
cpp* i386-rtems-gasp* i386-rtems-readelf*
gcov* i386-rtems-gcc* i386-rtems-size*
i386-rtems-addr2line* i386-rtems-ld* i386-rtems-strings*
i386-rtems-ar* i386-rtems-nm* i386-rtems-strip*
i386-rtems-as* i386-rtems-objcopy* i386-rtems-unprotoize*
i386-rtems-c++* i386-rtems-objdump*
i386-rtems-c++filt* i386-rtems-protoize*
i386-rtems-g++* i386-rtems-ranlib*
% ls /opt/rtems/i386-rtems/bin
ar* as* gcc* ld* nm* ranlib* strip*
Hope I am on the right track !
HELP !!!
Vasu
