open_mode
Eric Norum
eric.norum at usask.ca
Mon Feb 11 15:05:42 UTC 2002
Pattara Kiatisevi wrote:
> Thank you for fast response. At first, I did use the O_WRONLY flag but I
> couldn't find the definition of O_WRONLY anywhere in the RTEMS source
> (hmm, maybe I missed it somehow) so I happened to see
> #define LIBIO_FLAGS_WRITE 0x0004 /* writing */
> in the libio.h so I tried directly the value of "4" :-p
> So it works now (with O_WRONLY) but I have to define it manually in my
> application code (#define O_WRONLY 1). A better way is possible?
> Regards,
> Pattara
I don't want to deter your initial enthusiasm for using RTEMS, but
before posting to the mailing list you could perhaps try looking for
yourself. This sort of thing can easily be found with a quick use of
find/grep:
find /opt/rtems/ -name '*.h' -print | xargs grep O_WRONLY
/opt/rtems/m68k-rtems/include/sys/fcntl.h:#define O_ACCMODE
(O_RDONLY|O_WRONLY|O_RDWR)
/opt/rtems/m68k-rtems/include/sys/fcntl.h:#define O_WRONLY 1 /* +1 ==
FWRITE */
/opt/rtems/m68k-rtems/include/sys/fcntl.h:#define _O_WRONLY O_WRONLY
So, like on any POSIX-compatible system
#include <fcntl.h>
is all you need to get the required declarations (since fcntl.h includes
sys/fcntl.h), which are part of the newlib sources.
Eric Norum eric.norum at usask.ca
Department of Electrical Engineering Phone: (306) 966-5394
University of Saskatchewan FAX: (306) 966-5407
Saskatoon, Canada.
