Coldfire GDB BDM problem
Bill Butler billb at tnex.com
Wed Feb 20 23:17:17 UTC 2002
Subject: Re: Coldfire GDB BDM problem
>Bill Butler wrote:
>> Bill Knight and I are trying to get the GDB/Insight debugger working
for
>> a 5307 coldfire with a P&E wiggler REVA.  I am using versions gdb
5.0.
>> with Chris John's BDM add-ons. This is running on a 1Ghz machine
under
>> Win 2000, with the latest Cygwin environment.
>Did you build this version or was it the binary version that is
>available ?
It was built!
>> I am able to connect to the MCF5307C3 eval board and do a board setup
on
>> it. I can load a simple App onto it but that is about it. I set the
PC
>> to the start address but the step, step-into,... buttons are grayed
out
>> with only the GO button active. When I go to the console on GDB and
try
>> si, the PC register immediately goes to a flash address (resets).
>Insight on Windows has some problems. I recieved a mail a while ago
from
>someone who managed to get it to go but never a patch. I have never
been
>able to get it completely sorted out. Maybe we could take this off the
>RTEMS list as it is not related to RTEMS and see if it can be sorted
out
Thanks for the update. Do you know if the tcp/ip version is stable?
> Chris Johns, cjohns at cybertec.com.au
