boostrap failing
Jowell, Chris {D177~Roswell}
CHRIS.JOWELL at ROCHE.COM
Fri Jan 11 19:47:51 UTC 2002
OK I've copied the versions of autoconf and automake from SuSE 7.2 (which
works... Still!) to /opt/rtems/bin on my 7.3 box which helped.
But bootstrap still does not complete without errors, have I missed
something else?
Thanks!
Christopher
This is the error bootstrap produces now:
./c
./scripts
/usr/bin/m4: configure.in: 43: Bad regular expression `[[[\([[`""]]\)]]]':
Unmatched ) or \)
[configure.in:43[: error: [[[back quotes and double quotes should not be
escaped in: [[$as_me:__oline__: [error: RPM CPU for ${target} is
unknown]]]]]]]
]/usr/bin/m4: configure.in: 43: ERROR: Recursion limit of 250 exceeded, use
-L<N> to change it
./scripts-ada
./tools/build
autoheader: config.h.in is unchanged
./tools/cpu/generic
./tools/cpu
./tools/cpu/hppa1.1
./tools/cpu/sh
./tools/cpu/unix
./tools/updat
-----Original Message-----
From: Joel Sherrill [mailto:joel.sherrill at OARcorp.com]
Sent: Friday, January 11, 2002 1:01 PM
To: Jowell, Chris {D177~Roswell}
Cc: RTEMS Mailing List (RTEMS Mailing List)
Subject: Re: boostrap failing
> Hi,
> We have RTEMS 4.5.0 working fine on other workstations but
can't get bootstrap to work on a new PC with SuSE 7.3. I put part of the
error message below.
> I'm sure I've missed something simple but for the life of me I can't
figure out what.
> I used the pre-built RTEMS 4.5.0 toolset Linux rpms (Including the m68k
packages) and I've added the location of the toolset and the RTEMS_MAKFILE
to my path
> My autoconf is 2.52.44 and automake is 1.4p5-44 if that's interesting.
I think that's the problem. SuSE has updated the autoconf package. Ralf
and I talked about this a while back expecting this to occur eventually
in various distributions. The problem boils down to tools (including
RTEMS) that use autoconf/automake can end up being dependent on
particular versions of those tools. In this case, RTEMS 4.5-X uses
autoconf 2.13 and automake 1.4p5. RTEMS snapshots past the Aug/Sept
timeframe require autoconf 2.52 and automake 1.5.
Notice what I have on the main RTEMS development machine.
bash$ rpm -qa | grep auto
autoconf-2.13-5
automake-1.4-6
autoconf-rtems-2.52-0
automake-rtems-1.5-0
The rtems ones are in /opt/rtems. When I work with snapshots, I
bootstrap
with those at the fron of my PATH. Otherwise I use the ones shipped
with
the OS.
For now, you need to install autoconf 2.13 somewhere that does not
conflict with the default version installed and use that to bootstrap.
--joel
joel at OARcorp.com On-Line Applications Research
URL: <http://lists.rtems.org/pipermail/users/attachments/20020111/9a4f5df6/attachment.html>
