ISR
VALETTE Eric valette at crf.canon.fr
Thu Jan 31 08:47:18 UTC 2002
Angelo Fraietta wrote:
> in the rtems_irq_connect_data structure, is the function (in the
> following case isr_port_dev2) called in the context of the ISR?
> static rtems_irq_connect_data port_dev2_isr_data =
>  BSP_IRQ_DEV_PORT1_IRQ,
>  isr_port_dev2,
>  isr_on,
>  isr_off,
>  isr_is_on};
> BSP_install_rtems_irq_handler( &port_dev2_isr_data );
The answer is yes. The status is as follow :
	1) Interrupt enabled at processor level,
	2) Minimal scratch registers pushed on the interrupt stack (switch to
interrupt stack managed by software on PCC, and ix86),
	3) At PIC level (8259 emulation or SIU + CPM, or Openpic), the current
interrupt (+other interrupts depending on (software managed interrupt
priorities) is masked but acknowledged meaning that only what remains to
be done on external hardware to reenable the interrupt needs to be
performed,
	4) Upon return of interrupt the PIC status concerning enabled interrupt
at entry is restored,
Hope it clarifies the model.
    __
   /  `                          Eric Valette - Canon CRF
  /--   __  o _.                 Product Dev. Group Software Team Leader
(___, / (_(_(__                 Rue de la touche lambert
                                 35517 Cesson-Sevigne  Cedex
                                 FRANCE
Tel: +33 (0)2 99 87 68 91       Fax: +33 (0)2 99 84 11 30
E-mail: valette at crf.canon.fr    http://www.crf.canon.fr
